Unusual R/C Discuss Airships, Blimps, LTA, VTOL, Ground Effect Vehicles, Hovercaft and more.
Nitro hovercraft
Old 04-07-2008, 08:48 PM
brettkrupa
Default Nitro hovercraft
Me and a buddy want to build a nitro hovercraft, we both have tons of experience in helis, planes, boats and trucks. All we can find are hovercraft with little cox engines. We would like to use something more like an os .61 or something. Anyone have any experience or good links? A link to a kit maybe as this is our first hovercraft so we do not have much experience with the whole concept. We are quick learners though. Thanks, Brett
Old 04-07-2008, 10:15 PM
JATO TO THE MAXX
Default RE: Nitro hovercraft
Make your own, here is ours:
It's not much, pretty small. We redesigned it. The first one had a 540 sized motor to push it and a 280 size motor to lift it. Not much but it moved, no steering though. I redesigned one had a 370 size motor to push down and I was going to mount a Mamba on the back but never got around to it. Have to figure a way out for steering before we do anything else.
Thats sounds like it is going to be cool, a .61, wow. Keep us posted on how its coming along. Ours wasn't that big so I dont really know what to tell you. Not sure what you would use for a second motor, you could maybe have some go out the back and some route down to lift it. That way you only have one motor and a motor like that should be enough depending on how big you make it.
Old 04-08-2008, 03:00 PM
kebuttke
maybe a small ducted fan control line motor for the air cushion and then a ducted fan for thrust. the air cushion doesnt need all that much thrust.
Old 04-08-2008, 09:08 PM
JATO TO THE MAXX
If he wants to mount a .61 motor on there with a gas tank and everything it might need a little more to push the air down. Might get kind of heavy.
Old 04-09-2008, 08:27 PM
brettkrupa
well, I was thinking something like this [link=http://www.thewidgetforge.com/projects/half-a-hovercraft/]Hovercraft[/link] except 10 times bigger and bals instead of foam. Its expensive to guess and test when building stuff like this in a large scale so some general plan would be good. Anyone have any advice?
Old 04-21-2008, 10:00 PM
Swazzi2000
I too am krazi about hovercrafts and wanted to build my own RC electric or gas powered so i did some research. The only good one i found was by QuickTechHobby.com and it had the US Navy's LCAC, and the Army's SK-5 Gunboat etc.... I ended up getting a gunboat and now im in the process of building a custom fan shroud and finding the electronice for maximum thrust and manouverability... I will post pictures when i can...
Old 04-22-2008, 05:33 AM
rickster3057
Hi brettkruppa, try this link.....http://www.modelhovercraft.co.uk/
Here are some pictures i got from the web it shows the internal structure and fan set up not unlike some aircraft easy if you have built your own planes.
hope it helps,
Rickster3057
ID:	934465   Click image for larger version
ID:	934466   Click image for larger version
ID:	934467   Click image for larger version
ID:	934468   Click image for larger version
ID:	934469   Click image for larger version
ID:	934470   Click image for larger version
ID:	934471   Click image for larger version
Old 05-02-2008, 03:27 PM
ISIRC10
ISIRC10's Avatar
HaH!!!
rickster3057 beat me to the post...
That website inspired me to build the Griffon 2000TD
If you mount a nitro on the pusher motor then you will have a nitro hovercraft... I think? [sm=50_50.gif]
A video of one that proves the concept (although IDK whether the lifting motor is electric or whether it channels air from the nitro motor...)
[link]http://youtube.com/watch?v=j7fSVAx_l0Y&feature=related[/link]
Old 05-02-2008, 04:44 PM
brel
Banned
is it possible to split the drive from the nitro engine to provide lift and thrust at the same time. just an idea
Old 05-02-2008, 05:24 PM
ISIRC10
ISIRC10's Avatar
Thats what I was hinting at in the previous post, and some full size hovercraft operate that way, but with such a small scale that RC's work with, It would be hard to manuever (as soon as skirt is inflated, the hovercraft starts moving forward)
...If you split the drive...
that complicates matters a bit more, but who knows, it could probably be done
Old 03-03-2009, 12:50 AM
Swazzi2000
I know i am like MONTHS later than i said i was gonna post pics but here they are.... Its not gas but it works..
ID:	1149090   Click image for larger version
ID:	1149091   Click image for larger version
ID:	1149092   Click image for larger version
ID:	1149093   Click image for larger version
ID:	1149094   Click image for larger version
ID:	1149095   Click image for larger version
ID:	1149096   Click image for larger version
Old 03-05-2009, 12:09 PM
asmithnc
asmithnc's Avatar
ORIGINAL: brel
The answer to your question is yes. Please click the link and you will see a picture of a nitro hovercraft that has split the lift / thrust.
http://www.rcairboats.net/phpBB/viewtopic.php?t=1058
