Unusual R/C Discuss Airships, Blimps, LTA, VTOL, Ground Effect Vehicles, Hovercaft and more.
Rx/Tx suggestions
Reply
Old 03-04-2010, 07:03 PM
charleshuff1953
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Rx/Tx suggestions
I want to radio control my zero turn mower. I think I need to get a 3 channel radio as I need forward/reverse on each wheel (the mower has independent levers that control each rear wheel) and possibly a kill switch on the third channel...
Any advice on radio transmitter/ receiver / Servos is greatly appreciated. I have NEVER built anything like this before. The zero turn mower seems the best choice to control remotely and I already have one. Thanks for any advice at all.
charleshuff1953 is offline
Old 03-08-2010, 10:41 PM
Lorduss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Rx/Tx suggestions
for dual sticks you pretty much need to go with a cheap 4 channel airplane controller, and extra channels dont hurt you well find ways to use them
there are alot of even budget 6 channel systems, and since your on the ground you dont need to worry about reliability.
one note on any airplane controller the left side is a clicker for throttle, the right is sprung, you could replace one side to match the other, very simple in alot of radios with a little soldering etc.
that is probbly your best bet.
also for kill switch, may want to look into the failsafes, they cut powered if they lose TX signal, might help ya
Lorduss is offline
Old 03-08-2010, 11:32 PM
Lightfoot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 72 mhz radios are for air use only. You will need to stick with a radio that is intended for surface use.
Lightfoot is offline
Old 03-09-2010, 12:01 AM
charleshuff1953
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So, I think you are saying I need two servo's per stick? what do you think about this servo: http://www.servocity.com/html/heavy_...vo__25__l.html
could it be set to "zero" in the middle? I also saw this servo : http://www.servocity.com/html/hs-7950tg_servo.html that I liked just because it has metal gears. it goes from 0 to 180 deg. but I don't know if I can get it to always come to rest at the 90 deg mark. I need the sticks to center so the mower will stop when I release the controls.
Does "European Style" mean that the Radio joysticks both go up and down rather than one going left to right? do all the radio joysticks auto center? Do I need a radio for a airplane or a helicopter? I wouldn't want to try to modify an expensive radio to make both sticks auto center. does a four channel Radio have only two joysticks? Does a 6 or 9 channel have the same number of joysticks but just extra buttons?
I also am not sure if just any 4 channel radio will work. I assume the TX and RX must be a matched pair? so that the 4 channels (or six channels) al work together. I also need to be sure the servo's will work with the receiver? I wanted to get a decent radio TX and use it for more than one project. who knows maybe I might end up with one of those neat rock crawler rigs I have been seeing on the web...
I know that's a lot of questions, so I will stop here. Thanks....
Charles
Old 03-09-2010, 12:28 AM
charleshuff1953
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Howard,
I used google to search for surface vs. air radios...   so far all the surface radio's show a trigger (throttle) and a dial (steering).  Is this always true?  I know it will be much easier to control my zero turn with both joysticks (moving up and down, not left to right) then trying to adapt a trigger/wheel type controller...   Is it possible to get a non 72mhz controller that will fit the bill?
thanks,
Old 03-15-2010, 01:37 AM
Lorduss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
as far as his comment on air vs ground etc.
Legally, your supposed to use a ground freq with a ground vehicle, and air with air, airplane style controllers tuned to ground freq are a expensive and hard to find option, i dont waist the time when i need more than 3 channels on the ground.
dont worry about using a airplane controller, just make sure there is no RC airplanes within a couple of miles from you. usually that is not hard, most of the time you have to drive miles to even find someone using a RC airplane, just make sure no RC airplane fields or places people commenly fly are around you while using this,. get away from it at all possible so you can be *safe* for them and you while you do what you want. im going to get crap for saying that but if you want to go through the effort for a controller that you have one use for, and no one wants to buy when you decide to sell, thats up to you.
Im going to get crap for telling you this, but im just being logical, its all be looking out for your self and others, your probbly going to only use this at home, you have probbly never seen a RC airplane within miles, as long as that stays fact you well have no problems using a airplane controller.
Im not sure exactly what european style means, you may want to search that further, No you do not need 2 servers on one stick or one channel, you can have that if you want.
That servo *should* work fine, you want a high torq servo and that is one, im not sure about your mower they are all different, you may need to buy one and experiment with it, see how it pans out. when it comes to servos options are endless seriously.
also, airplane and heli controllers are basicly the same, the left side is a clicker, the right side is completely sprung, in more detail, the left stick is known as throttle/rudder, throttle being forward and back is on a clicker, it well sit where you leave it, the rudder fuction is taking that same left side stick, and moving it left to right.
one stick can control 2 servos indepentantly. the same for the stick on the right, except no clicker, one function is forward reverse, the other side to side, in other words 2 sticks control 4 channels completely on there own (Before you include buttons)
6-9 channels only difference is buttons, there is no radio that i know of with a 3rd stick honestly i think some people would be interested, i just dont know of it yet, at least not common.
as far as your servo returning to center, thats what they do normaly, when you turn on your servo you have a trim ajustment on the radio, center that and put your servo arm on centered where you want, you can trim from here, the servo well allways return to this netural position every time you let go of a sprung stick on the TX, your arm throw well have to be ajusted by the lenght of servo arm, or the position of the arm is controlling, in other words think leverage. when the servo/RX and TX are all off, the servo can be pushed around, when everything is on it holds a position that matches the stick that controls it.
that servo you linked to is complete overkill, you can get a high torq servo for about 60 bucks that well probbaly do the job. depends alot on how much throw you need and how much resistance it receives, you may want to do a little trail and error with this like buying maby a single servo. but the one you link to is a linear actuator, kind of like a hydraulic cylinder replacement, you can downgrade, but if you want to use that i KNOW it has enough distance and power to push! but you mentioned cost so =)
you also DONT need a digital servo, unless your flying high end Airplanes or driving a RC car in a serious race, but for your project style you just need analog.
the difference is a fine level of precision at increased price, you wont notice it at all with a project like yours.
http://www.servocity.com/html/s9157_servo.html i have a feeling this would still be overkill, but it would be far more cost effective than those big guys you linked to.
check the specs on that, 425 OZ of pushing power with a 1 inch arm, thats 25 pounds ish, if you make the arm 4 inches you cut that number in 4, its probbly still more than enough to push your levers around. then you just need to get a long servo arm off servo city, it would come with about a 1-2 inch arm at most infact call servo city and ask them about that, some of those monster servos may actually come with something decent now, i have had to buy aftermarket long servo arms for years for stuff.
i know the travel distance on those levers are probbly quite a bit, there is a whole equasion to figure out but im giving you the right idea.
as far as how compatible everything is, Your TX And RX need to be the same if FM or AM and also need to both be for 72 mhz only (72 is air) eather way that needs to match. basicly your looking for FM 72mhz TX and RX
Other than that, they pretty much work just fine, when you look up servo's they mention something like a Futuba J plug ( very popular) or a Airtronics style plug(not as popular)
those are the 2 majors, minor plug difference and the wires are in a different order if i rember, i would say stick with a futuba plug style setup, its extremly common and easy to use. As long as your servos are ment to plug into your RX, they well allways work. Servos are completely compatible as long as your plug type matches.
i think i covered your questions, if i forgot anything you have anything else to ask let me know.
edit: metal gears are cool, and now often cheap but i wouldnt consider them required for your project, they realy come in handy on 8 pound RC cars that get tossed around and slammed, the servo needs metal gears to combat the abusive forces and not break, for those servos pushing levers its not needed, but dont try to avoid it it probbly wont add hardly any cost, just a FYI that its not completely needed.
Lorduss is offline
Old 03-18-2010, 08:02 PM
mundo330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What you need to find is the old ACE Nautic Commander 5 channel Radio. It was on 75mhz and had two throttle sticks and a rudder stick with 2 additional channels. You could use the throttle sticks for steering and one of the aux channels for throttle control and the other for a start/kill switch. As far as I know they do not produce this radio any more, however you should be able to find one on the boat forums.
mundo330 is offline
Contact Us Archive Advertising Cookie Policy
