1031 Skull Quadcopter!
Unboxing
https://www.youtube.com/watch?v=0TfV8eTVxxI Flying https://www.youtube.com/watch?v=q_n_a8yCn98 Get it at Gearbest : https://goo.gl/7k25jc This is too cool! Hope you enjoy the review, be sure to check out the my other videos next!! This is a great flying quad, and looks awesome, the prop wind makes the ghost look alive, at night its easy to see as you fly, it flies very well, and is alot of fun! PRO: - Lots of power - Flies great - A key return works - Triple rates so you can fly in some wind - Lights look great when darker out - Spare props and gears - USB Charger CON: - Odd battery plug Gearbest Specs Description: This skull shape quadcopter can get you prepared for the upcoming Halloween. Its lighting effect in the darkness scares everyone to death. Roll the ghost in mid-air and do this at a different speed, and the petrified person cannot but stumble forward. Have fun playing tricks on others! Main Features: - New High in Playing Tricks Don't need to rack your brains anymore. The awesome drone does all that you can't do, such as drifting and spinning in the sky, emitting scary lights. - Artful Speed Adjustment When your "prey" thinks the ghost is left behind, speed up your copter and compel that person to cry out. - Headless Mode You can get the hang of piloting the UAV in different directions easily since you can ignore its front while it goes to wherever you want. - One Key Return When you think it is time to show mercy to the frightened fellow, recall your drone instantly with this function. Specifications General Type: Quadcopter Model: 1031 Features: Radio Control Functions: 360 degrees spin,Forward/backward,Sideward flight,Slow down,Speed up,Turn left/right,Up/down,With light Built-in Gyro: 6 Axis Gyro Night Flight: Yes Kit Types: RTF Level: Beginner Level Connectivity Remote Control: 2.4GHz Wireless Remote Control Channel: 4-Channels Mode: Mode 2 (Left Hand Throttle) Detailed Control Distance: 80~100m Transmitter Power: 6 x 1.5V AA battery(not included) Model Power: 1 x Lithium battery(included) Battery Battery: 7.4V 850mAh Flying Time: 6-8mins Charging Time (h): 150-200mins Dimension and Weight Product weight: 0.308 kg Package weight: 1.358 kg Product size (L x W x H): 60.00 x 34.00 x 75.00 cm / 23.62 x 13.39 x 29.53 inches Package size (L x W x H): 40.00 x 22.00 x 37.50 cm / 15.75 x 8.66 x 14.76 inches Package Contents Package Contents: 1 x Quadcopter, 1 x Transmitter, 1 x Battery, 4 x Spare Propeller, 1 x Screwdriver, 1 x Chinese-English Manual |
Bought one...love it...waiting for Halloween
