MKB 5588-610 Stunt car review
My Feedback: (38)
https://www.youtube.com/watch?v=aOY1KB2Eu0E
Where I got it: https://goo.gl/PpLDsH
The fun driving part of the review, enjoy! Dont forget to subscribe!
Not going to lie, this is pretty fun, and kids LOVE it, you just shove the sticks in different directions to make it do crazy things. It did better in the gravel and grass than I thought it would, but its definitely better indoors or on smooth surfaces.
The battery lasts a long time as well, all in all a pretty fun machine. The sticks are not proportionate, its either on or off for movement, but it still works fun. The trickiest part is if the body flips, then forward is back, and back is forward, but its easy to make it jump the other way.
PRO:
- FUN
- Price
- Run time is great
- Easy to operate
- TX batteries included
- USB Charger
- Great for kids and indoors
CON:
- Lights on top and bottom should be different color to help with
direction
Description:
This is an awe-inspiring crawler that has two identical sides and two rotatable lines of wheels. With the multiplication of four different ways of control, you get more than a dozen of spectacular stunts!
Main Features:
- Shining Talents
The number of the skills that it masters is so amazing. There is no doubt that it can deliver wonderful performances.
- Marvelous Agility
The wheels can rotate very quickly along with the body thanks to the considerate aerodynamic design.
- Easy to Operate
It provides you with a foolproof way of steering - you just need to move the joysticks either up or down.
- Long-lasting Fun
The car is super power-saving. After the first charge, you only need one hour's recharging in order to play for 25 - 30 minutes.
- Shock-resistant and Splashproof
It can show up when rolling down from high stairs, and the clever battery compartment enables the car to run past puddles.
Specifications:
Brand: MKB
Model: 5588 - 610
Weight: 0.457kg ( not including battery )
Material: ABS
Features: 360-degree rotation, 360-degree transformation, off-road running, LED lights, robust lateral parts, aerodynamic design, fall resistance
Motor: brushed
Signal frequency: 27MHz
Channels: 4
Control distance: 10m
Car battery: 6.4V 400mAh 2S lithium-ion battery, 38g
Charge time: 120 minutes
Charging method: USB cable
Run time: 25 - 30 minutes
Transmitter battery: 2 x 1.5V AA ( included )
Specification
General
Brand: MKB
Type: RC Cars
Motor Type: Brushed Motor
Features: Radio Control
Functions: Climb,Forward/backward,Stunt,Turn left/right,Wheel flip,With light
Material: ABS,Electronic Components
Primary Technical Info
Remote Control: Radio Control
Channel: 4-Channels
Detailed Control Distance: 8~10m
Transmitter Power: 2 x 1.5V AA battery(included)
Car Power: 1 x Lithium-ion Battery
Racing Time: 25 - 30mins
Dimension and Weight
Product weight: 0.457 kg
Package weight: 1.322 kg
Product size (L x W x H): 18.00 x 18.00 x 8.00 cm / 7.09 x 7.09 x 3.15 inches
Package size (L x W x H): 40.00 x 22.00 x 22.00 cm / 15.75 x 8.66 x 8.66 inches
Package Contents
Package Contents: 1 x Stunt Car, 1 x Transmitter, 1 x 14500 6.4V 400mAh Lithium-ion Battery, 2 x 1.5V AA Battery, 1 x USB Charging Cable
PRO:
- FUN
- Price
- Run time is great
- Easy to operate
- USB Charger
CON:
direction
Description:
Main Features:
- Shining Talents
- Marvelous Agility
- Easy to Operate
- Long-lasting Fun
Specifications:
Brand: MKB
Model: 5588 - 610
Material: ABS
Motor: brushed
Channels: 4
Specification
General
Brand: MKB
Type: RC Cars
Channel: 4-Channels
Package Contents
