User Product Reviews Post a full review of your latest kit, ARF, heli, engine, radio, whatever! Read what others have to say about them.
No BS Batteries
Reply
Old 09-27-2004, 07:32 PM
Red Scholefield
Banned
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default No BS Batteries
I had a chance to look at these packs. No BS Batteries is owned by Steve Anthony who worked for S&R as the head shop guy.
No BS Battery Analysis
Transmitter Pack 8 cell Sanyo 800 AA 2 X 2 X 2 config. Date code IA (Jan 04)
Receiver Pack 4 cell Sanyo 800 AA Flat pack Date code IA (Jan 04)
Receiver pack had 20 mil over sleeve (most manufacturers use 6 mil). Lead wires 8” long awg 20 wire (most manufacturers use 4-6” long w/awg 22 –24). Futaba J connector w/gold flashed pins. Stress relief on lead provided by 1” filament/strapping tape. Weight 101.2 grams vs. 88.1 grams for Futaba 4 cell AA 700 mAh pack. Cell interconnections .187” X .005” thick nickel straps triple welded (Futaba packs double welded Ni-plated steel – some other pack assemblers use .158” wide tabs). See photo. Pack voltage as received 4.48 volts suggesting unformed cells. (Sample not selected for this test). Discharge @ 250 mA after 24 hour charge @ C/10 (80 mA) 991 mAh to 3.6 volt cut off (123% of rated capacity).
Transmitter pack OCV as received 8.34 volts (unformed cells). Discharge @ 250 mA after 24 hour charge @ C/10 (80 mA) 969 mAh to 7.2 volt cut off (121% of rated capacity). Pack over sleeve 6 mil (standard for transmitter packs). Leads awg 22 wire with Futaba J connector w/ gold flash pins. Interconnecting straps.187 X .005, triple welded, cell sticks connected by folded tab. Fiber insulation plate used on each end of pack.
Discussion: The No BS receiver pack employs heavy-duty construction that is as good as I have ever seen. The techniques used result in an overall lower pack resistance than packs using the same cells from other cell assemblers as well as a pack that is more resistant to shock and vibration seen in the R/C aircraft environment. Transmitter packs while essentially the same type of construction as other pack providers are of top quality assembly.
One each of each type tested. Test device – Alpha 4.
Notation for attached picture.
Pack welding.
Futaba pack at top
No BS pack at bottom
Red’s R/C Battery Clinic
9/25/04
Red Scholefield is offline
Old 09-28-2004, 09:32 AM
Lee Belew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: No BS Batteries
Red
I for one want to thank you for this information. This is probably the best info I have seen reported on battery packs that are available for purchase. I have worked with this type of things for approx. 35 years and I really do think you for your information for us flyers expecially us seniors.
Lee Belew
Lee Belew is offline
Old 09-28-2004, 12:03 PM
Hangtime
My Feedback: (19)
Hangtime's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Red, my humble thanks for your review!
So that folks may find us on the web or locate forum discussions mentioning our packs try also NoBS (without a space) Batteries, and our website home is at www.hangtimes.com
Thanks again for the analysis!
Hangtime is offline
Old 10-01-2004, 05:57 AM
DBCherry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks from me as well Red.
I place a lot of faith in your assesments and your advice in general. I use to follow your columns when you wrote for whatever that magazine was. (The one that I dropped my subscription to during all that controversy.)
I for one will be buying my next packs from No BS.
Dennis-
DBCherry is offline
Old 10-01-2004, 06:46 AM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I picked up a few packs from him at Joe Nall. He made them up just for me right on the spot and they are doing a great job. Steve also spent some time with me discussing charging and chargers and gave some great advice. After my time spent with him I have much more confidence on how to accurately charge my batteries.
Thanks for a great product and friendly service!
PS. did you ever get the Dymond ST instructions I sent?
Vic in NC
vicman is offline
