If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
Thread: will it work
  1. #1
    spec36's Avatar
    Join Date
    Feb 2006
    huntsville, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    will it work
    a vpp on a yak54f and if so what is the best way to go .
  2. #2
    spec36's Avatar
    Join Date
    Feb 2006
    huntsville, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: will it work
    thanks for no help on last 3 post by spec36 flat line tread __________________________________________________ __________________________________________________ .
  3. #3
    Join Date
    Jan 2005
    Derby, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: will it work
    Sorry, man, but do some research. Look at what motor people are using on this plane, then find a comprable hollow shaft motor. It's not that complicated. It'll take some work to get mounted right, but there's no reason it wouldn't work.
  4. #4
    spec36's Avatar
    Join Date
    Feb 2006
    huntsville, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: will it work
    thanks Ryguy I have been looking for two weeks and im lost i run a 400outrunner now on the yak54f .. not sure what is the best way to go the plane is @ 13.5oz . wish i could see pics. of how someone setup one and is the motor inside or out ? it would be easy on one of my f3a but would like to set it up on the yak thanks for the reply first one I got ... tryed in the vpp and video and so more but maybe i did not look enough
  5. #5
    Mato's Avatar
    Join Date
    Jan 2004
    Buenos Aires, ARGENTINA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: will it work
    I think that with the right setup, the VPP on that aircraft should work. Just take a look to the Byp Yak of QQ and you will notice that he is using the new e-flite VPP and a 370 outrunner....
    I have the AXI 2212/34 hollow shaft and I have problems running my Ikarus PPS, so I asked if someone know what setup quique is using and here is what a RCU member said:
    [link]http://www.rcuniverse.com/forum/m_4186502/tm.htm[/link]
    CAP 232G H9-ZDZ 50NG
    Hovering Cobra-Electrify
  6. #6
    Join Date
    Jan 2005
    Derby, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: will it work
    You should look into the Mamo-models VPP. It's due in May, and can be used on any outrunner. Hoerver, it only has a 9-in. prop. It'll be distributed by Horizon.
  7. #7
    spec36's Avatar
    Join Date
    Feb 2006
    huntsville, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: will it work
    thanks i found more info to and found pic.s now i got to learn how to set up the tx i saw the other tread on that... sorry for post #2
    and i would like to get one of the new bypyak
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
