Non heli TX VPP setup
VA
RE: Non heli TX VPP setup
You'll have to figure out a way to mix the throttle and pitch similar to the curves availabl on a heli Tx. You should be able to setup a mix or throttle and (channel pitch is on). I know the 10SX has a lot of mixing options, but I don't them very well. I suggest you set up 2 mixes actually. 1 for nomal flight mode and 1 for vpp flight mode.
I was wondering about the same thing. I fly airplanes, may someday get a heli, but am looking at one of the new Spektrum DX-7 radios.
Does anyone know if you can set up a VPP setup on the airplane version of the DX-7?
VA
If it has heli programming, and I believe it does, then sure you can. Remember you'll have to set up the airplane in heli programming, but it's no big deal.
