If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 268 of 380 FirstFirst ... 168218258266267268269270278318368 ... LastLast
Results 6,676 to 6,700 of 9494
  1. #6676
    Join Date
    Mar 2007
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Walkera #4 Fixed Pitch Helicopter Forum
    It works fine for side to side. Its not hooked to the tail for left ,right But what about the problem with my tail motor problem not having any problems with the way my gyro is mounted
    uP up AND aWAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  2. #6677
    GTX SlotCar's Avatar
    Join Date
    Oct 2005
    Gorham, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did you have the problem before installing the ducted fan?
    Gary
    SuperSkidsยฎ
  3. #6678
    Mdhat's Avatar
    Join Date
    Feb 2007
    Lockport, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Gary,
    Mdhat here, got my Super-Skids and Grips today , Thanks for the quick shipping. They look great, cant wait to install them. AWESOME PRODUCT!!!!!! Everyone should check them out. I'll pass on the word.
    Thanks Again,
    Tom
    !!FLY to survive and survive to FLY!!
  4. #6679
    Join Date
    Nov 2004
    Carol Stream, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Rollin:
    I discovered a problem with the DD Tail Rotor we've been using and wondered if it has affected you.
    I noticed tail wagging begin a few days ago and upon close examination of the motor, adapter and rotor blade, I could clearly see that the adapter (which is really tiny) was bent. Has this happened to you? Does there exist a more substantial adapter we could use for this system? Thanks.
  5. #6680
    Join Date
    Mar 2007
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes I did thats the reason for changing the tail motor.I thought it was the stock motor making it do it. But it did not change after installing the ductfan,
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  6. #6681
    Join Date
    Oct 2005
    Gorham, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, if it was mine, the next thing I'd do is replace the main motor with a stock one or an E-flite/Esky 10T motor. At this point the 4in1 is usually the first thing blamed, but the last thing to actually cause a problem. I'd try a new main motor. If I just replaced the main motor, I'd still try a new one.
    Gary
    SuperSkidsยฎ
  7. #6682
    Join Date
    Mar 2007
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did replace the main motor that not the problem. But thank for your help.Sorry about the poor pic only camera I had at the time
  8. #6683
    Join Date
    Oct 2005
    Gorham, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    In order to solve the problem, we have to take it in logical steps. The first would be to fix the gyros. The 4in1 must be standing up as it does in a stock DF4. The added gyro must also be upright. I'm not really sure how you tied the outboard gyro into your 4in1 and it would be easier to solve the problem without it, but I'll assume you found a way to wire onto the 4in1 board between the 2 ESC circuits.
    If the problem was happening before you added the new tail, gyro and turned the 4in1 on its side, then it could be a glitch cause by a bad connection in the motor's JST connector. Whenever I've had a glitch, it's been caused by a bad electrical connection. Sometimes rerouting the antenna can help (but not stop it altogether), but fixing the right connection will stop it.
    Gary
    SuperSkidsยฎ
  9. #6684
    Join Date
    Mar 2007
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for that I will try all you said.I thought about the 4in1 but did'nt try it yet. Thanks again for the help
  10. #6685
    Join Date
    Oct 2005
    N, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mcflyman
    I use the same gy006 gyro in the #4 and works great with the stock tail motor, you have to position the gyro upright (when you can read the blue label), not side way. If you use the stock #4 radio, set the AVCS on and gain/sensitivity at ~55%, you're good to go. If you use other Tx, make sure the Revo mixing is off in the AVCS mode.
  11. #6686
    Rollin Thunder's Avatar
    Join Date
    Feb 2006
    New Lexington, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    helirook
    After many crashes with the DD I have not had that happen. What you are looking at is crash damage. It's not a problem with the adaptor it's just damaged. Really we don't have any room to complain compared to most others here. So far it has been as reliable as my belt drive heli. Answer me this. Before now, when was the last time you even thought about your tail? I don't know of any adaptor that is stronger steel. I would just replace it. Hell it's even cheaper than a stock motor
    ORIGINAL: helirook
    Hey Rollin:
    Take a method and try it. If it fails, admit it frankly, and try another. But by all means, try something.
    F.D.R.
  12. #6687
    Join Date
    Oct 2006
    Rochester, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: E_Heli
    Mcflyman
    If youy are using the stock RX where are you plugging the gy006 in?
  13. #6688
    Join Date
    Oct 2005
    N, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ironsmith
    No, I went separates when the 4in1 quits after 55 flights. Do a search, I did a BL setup here also.
    With the gy006, all you need is a regular 4 channel radio, that's beauty of the HH gyro, you don't have fool around with the Revo or throttle/rudder mixing.
  14. #6689
    Join Date
    Jun 2005
    Sydney, , AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gidday all,
    I am still considering what my options are for the tail motor setup with the DF4#1. I am reading godd things about the GWS direct drive setup. However, with all the information in this thread, I am having trouble knowing exactly what parts I will need.
    Has anyone got a list of GWS part numbers?
    I belive I need:
    Direct drive motor
    Mounting fin
    Blade adapter
    Any assistance would be appreciated.
    Steve
  15. #6690
    Join Date
    Feb 2007
    Antioch, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, learning to fly the dragonfly progresses, I can keep it in the air for most of a battery, but not really hovering as it takes me about a 15 foot square, which I can barely keep the heli in...
    My original reason for getting my walkera came from an interest in micro-controller development and robotics, I had wished to make a small heli "fly itself" the DF4 seemed perfect as it is a fixed pitch heli (less for the computer to do)...
    To this end, I am developing a small board (same size as a small receiver) with some sensors (of different types) that will plug in between the receiver (until the receiver is not needed at all) and the servos, motor Esc(s), etc... with my board actually controlling everything, and the receiver just giving it directional inputs, to do this I must go separates, my board will be able to receive and send servo type signals,
    I think I need to get: (tell me what parts you recommend, and tell me if I forgot something I need)
    Gyro (heading lock preferred)
    main Esc
    tail Esc
    servos (better then stock)
    mixer?
    bec?
    receiver (4-6ch)
    tx
    P.S.
    I am not expecting any of this to allow me to fly the thing better, just so I can connect a computer to fly it for me...
  16. #6691
    Join Date
    Jan 2007
    Canyon Country, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: richcreations
    richcreations,
    I think that would be very cool to see indeed.
    But first, before you could do that you would have to really understand how to control your helicopter. The DF4 is a great helicopter to learn on because it is so difficult to fly that when you move to stable helicopter you are like an expert!
    Second a couple of people I have seen go seperates with the DF4 are locked into problem after problem mode. Either with the gyro or getting an esc to arm right. Seriously I would suggest looking at a different platform, such as one that is already 98% what you need. If you want to push forward with this all-in-one dual engine platform, I might suggest you look at this persons helicopter and shoot him a PM. By the way that's a Heli-Fever.com frame.
    http://www.rcgroups.com/forums/showp...postcount=1774
    Very interesting project! Please keep us posted.
    HS
  17. #6692
    Join Date
    Nov 2004
    Carol Stream, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Rollin Thunder
    helirook
    ORIGINAL: helirook
    Hey Rollin:
    I agree Rollin. It's a great set-up and yes, I did slam the tail which probably resulted in the bend. With this in mind. I'll just reorder a few extras plus the replacement. By the way, the motors sure seem to last quite a while!
  18. #6693
    Join Date
    Oct 2005
    N, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    richcreations
    Great idea! Here's a link for the FMA co-pilot for your reference:
    http://www.fmadirect.com/products.htm?cat=29&nid=7
  19. #6694
    Join Date
    Oct 2005
    N, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I read an article awhile back, someone writing a program to port to Linus system and successfully controlling RC helicopter using the infra-red interface. Google it.
  20. #6695
    Join Date
    Feb 2006
    New Lexington, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Stevo
    GWS Dragonfly FP helicopter Direct Drive Tail System.
    Tower Hobbies shopping list (you don't really NEED the fin)
    Stock #
    LXHHE2
    LXHHN4
    LXHHF7
    LXHXK4
    ORIGINAL: stevo1957
    Gidday all,
    I belive I need:
    Direct drive motor
    Mounting fin
    Blade adapter
    Steve
    F.D.R.
  21. #6696
    Join Date
    Oct 2003
    Mooresville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Mcflyman
    Can anyone help me my tail motor keeps surging for some reason. If I unhook the main motor and run it the tail motor runs great, but when the main motor running with the tail motor will run hi lo, sometimes spinning the heil into 360 turns. I just install the ductfan tail and upgraded the main motor. Even took a old WK-G006 gyro i had off my #36 I dont us anymore works great with the new servos. With the new superskids it looks great . Now the problem the tail motor, need help
    Looking at how you have the gyro mounted that looks to be the cause. That gyro needs to be mounted upright, NOT on its side. It will never work proparly with the way you mounted it.
  22. #6697
    Mdhat's Avatar
    Join Date
    Feb 2007
    Lockport, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What heat sinks fit the main and tail motors on a DF4? Where can I get them?
  23. #6698
    Join Date
    Jul 2006
    San Francisco, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the same ones as the Blade cp/cx ones by e-flite
    your LHS should have them
    If I were a stone, I would rock
  24. #6699
    Join Date
    Feb 2007
    Phenix, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is what i bought I'm happy with it so far, everything came in one peace and works great. Once I balanced the blades and took off the training gear it actually hovers like a dream. This is my first RC anything and i can hover tail in and nose in after the first day. Not to bad. My only problem is the battery didn't come with instructions and i don't know how long it takes to charge it. I assume the red light turns green when it is charged but I'm too afraid of over charging it. If anyone could help me out the link is at the bottom for the kit i bought.
    http://www.rc-expert.com/product-package.php?pid=149
    John 3:16
    For God so loved the world that he gave his only begotten Son that whoever believes in him shall not perish...
  25. #6700
    Join Date
    Sep 2006
    Burlington, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok damn it i'm getting one. I've been reading about you guys having a blast with your Heli's now i want one. My question is where can i get one over nighted? I live in Jersey and i want it ASAP. A couple sites i went to dont offer next day air. Only 3-4day. So where do i go? thank Joe
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
