Walkera #4 Fixed Pitch Helicopter Forum
#7927
MD
RE: Walkera #4 Fixed Pitch Helicopter Forum
Dafx, the back rod that holds the tail up is glued in. CA un-bonder and time will get it out. Some break it off and drill out the 2mm rod.
EDITED: Unless of course you are trying to mount superskids, then follow GTX's instructions. He is the undisputed expert on the Super-Skids. :>
#7928
ME
ORIGINAL: DaxFX
How Can I take out the rod that holds back fin and touch the ground. to put on the new fin
You should cut your new fin to look like this picture, then tape the bottom to the rod. If you don't do this, your fin may rotate around the tail boom and get caught in the tail blade.
#7930
ME
LOL. Did you see the video about it on youtube? It's gone now, or at least I can't find it anymore. The pilot was a beginner flying outdoors. He bounced the heli off the grass a couple times and finally got it airborne for a couple seconds, then landed it. On his next take-off, the heli was a couple feet up when the tail rotor caught the fin. Looked like the tail blade broke and a piece went flying by the camera man. You could see the camera dart to one side and he said something I can't repeat here.
If anyone can find this video again, I'd really like to have the link. I'm pretty sure it was youtube, but not certain. There are so many of those sites now. It was a FP heli, I think either a DF4 or HB FP, and the title also said superskids, but they weren't SuperSkids. In the (sort of) close-up, you could see the circle instead of a V in the rear mount, despite the rather low quality of the video. The pilot looked Asian, but the cameraman knew at least one word in English.
#7931
rofl knew one word in English!
No I didn't see that video but I have done some really dumb stuff which resulted closely to that.
#7932
ok I will let the rod there The fin is not the same as the carbonfiber you got there but same idea. I have afraid that the fin of the extreme skid are going to twist and damage tail blade so I use a little tiewrap and wraped to the rod on the bottom part.
#7933
ME
Good job. Now you won't have problems there.
Is it possible for you to take a picture of the how the struts (wire that goes from the wing to the landing gear) are screwed into the landing gear?
#7934
Quick question regarding my rotor head / blade holder .........
I just bought a DF4, seems in very good condition, the top of the rotor head had sheared off and the blade holder was missing, quick trip to local model shop sorted that though.
Have reassembled it all (correctly I think) with new bearings and blade holder etc, are the main blades supposed to be a bit "stiff" to rock across the top of the rotor head? I can't see anything I've done wrong, it looks the same as all the pics I've looked at, you put the bearings on either side of the rotor head, using the little screws, then simply snap the blade holder on top of that?
Thanks in advance for any help!
#7935
MD
The earlier versions had screws that held the bearings in. Now that you have replaced the head, it may be newer and not have room for the screws that retain the bearings. I run my heads without the screws. A little more risk when you shear the head off, but more often than not, the bearings remain in-place.
Try removing the screws and see if the head moves more freely.
Michale
Michale
#7936
ME
I think it's assembled right. Sometimes the dogbone links fit too tight and the head doesn't move freely
Michael, the new ones don't have screws? That's good to know. The old ones didn't, then the new ones did, and I guess now the newest ones don't again.
#7937
ORIGINAL: GTX SlotCar
if is that i wrap arround the front plate of the skind and thru the straw.
#7938
I need to know something The canopy have the holes for the normal skid but with my extreme ski the holes does not match position with skid.
#7939
Appreciate the help, thank you!
Screws are now out and guess what ................................. [8D]
The blades swivel more freely than a Liverpool girl gives her love!
Many thanks!!
Many thanks!!
#7940
You gotta admit Gary is a stand up guy for helping people with products that aren't Super-Skids.
Generally you have to trim the canopy to fit a little.
#7941
ME
ORIGINAL: DaxFX
What cable you are talking about ... ....
#7942
ME
ORIGINAL: DaxFX
Here's the SuperSkids manual. It should help you with the canopy mount. It's in pdf format, so you'll need Adobe reader to view it. Adobe reader is free.
http://www.act-labs.com/pdf/SLG300%2...n%20Manual.pdf
#7943
NC
Need help tring to go BL on my DF4 ,but i am a bit lost what do I do with the red/black wire from the ESC do I run it to the battery then what to do with the power wire from the RX should I make a Y con.
#7944
MD
The ESC has 3 sets of wires.
1) RED/BLACK. Large thick wires = Battery
2) 3 Wires (can be various colors) = Motor
3) 3 small wires with plastic end. Ch3 (or whatever your throttle channel is).
If the motor runs in reverse, switch any of the 2 MOTOR wires. that will make it run the other way. Or if you have a programmable ESC, then change it in that setup.
Those instructions were for a standard heli, not a 4&1 heli, like the #4. Sorry, I just replied with stock ESC answer instead of seeing that I was in the #4 forum.
It is not possible to hook the Brushless ESC directly to the stock 4&1.
You need a product like this:
http://www.ushobbysupply.com/product...roducts_id=386
or this:
http://www.ushobbysupply.com/product...roducts_id=423
Sorry for the confusion the first time around. PM me for more detailed instructions or whatever you need.
Michael
both are good. They allow you to use the stock 4&1 and use the PWM output of the 4&1 to drive an ESC.
or this:
Michael
#7945
NC
Thanks Michael I just made a order with you today for the pinion and Main gear.I see you shipped it out already.So the power wire on the RX is not used with the BL motor.
#7947
No. I meant the back. There are 2 struts that go from the wing to the landing gear. I wanted to see how they're both attached to the landing gear.
ORIGINAL: DaxFX
I having a drifting problem it goes in circles counterclock and backward direccion. I have to make about 20 circles around me untill I get a hover and only for 2 or 3 seconds then drifting again. my only good experience is with CX2 so I a new flyer on tail rotor helis. I understand fisics and how heli acts. but i am learning how to react. it will posibble to get hover with hands out on this heli with correct settings and trim. any advice on how to get the easy way to fly this thing.
#7949
MD
You can move the swash control rods to a hole closer in on the servo arm. It will slow response down (good for a beginner)
Michael
Michael
#7950
ofter moving on hole in the swash plate will be out of place I will need to adjust the lenght of the likage? or I will be able to correct with just trim?
