Walkera #4 Spinning out of control
Hi,
I am a new as they come... I purchased a Walkera #4 and I can't seem to get it from spinning counter clockwise when I throttle the heli up.
Please what am I doing wrong and how do I correct this out of Control Walkera !!!
Eddie
Eddie
My Feedback: (10)
RE: Walkera #4 Spinning out of control
New or used? If new, try to plug the helo to the battery and wait 10 seconds. Then before turning on the radio make sure the throttle and it's trim is all the way to minimum. If the motor fails to turn, it may be bad. If you have a voltmeter check the leads and see if you have voltage. Be careful of the rotors. I would remove them when checking this. If you have voltage then the motor is bad. Good luck.
I had the same problem with mine. Probably a fried rear motor. Take the canopy off and check that the cable is plugged in.
