#36 main shaft removal
I'm struggling to remove the main shaft of my #36. So far I've:
[ol][*] Removed aileron see-saw from swash[*] Removed elevator servo linkage from swash[*] Undone and removed grub screw on pitch servo[*] Undone and removed main gear grub screws
[/ol]
The main shaft is now loose but it gets stuck after pulling it out about 3-4mm and won't go any further. I've tried yanking it harder but I'm afraid I'll break something. I can't see anything else to take off. Any suggestions?
[/ol]
RE: #36 main shaft removal
I haven't yet removed the whole rotor head, do I need to do this first? Should I be using the t-bar/blade grips to do the yanking? Thanks!
Hi
I removed my 36's main shaft and after re-assembly the pitch rod that runs through the main shaft does not turn with the main shaft. It is still loose after tighening the grub screws on the main shaft. What am I doing wrong?? Please assist
Hi
