ESKY Servo on Walkera RX
Hello Guys,
I am not sure if the ESKY 8g servo can be used on the Walkera RX. am sure that the ESKY servo does not use the Futaba J type connector as seen on the pics on the net bu can I use this tyoe of servo? is it any good than the stock servos walkera give out with there helis. i somewhat busted one of my servos on my DF40. can I use the Esky one. Has anyone tried this
thanks
thanks
RE: ESKY Servo on Walkera RX
I have to chage the servo horn? why does ithave a different fit? how about the HS 55 but i find the hitec servos a little expensive... do you also need to replace the servo horn on the Hitec?
Have changed my servos with the 8g Esky ones it works better and faster than the walkera servos better response... and cheaper too... almost got the HS-55s I never knew that this hitec servos were only built here in the philippines... always taught that they were assembled at Korea... well they still sell them expensive here... almost the same price as the ones in the market ... I wonder if i could get some from the factory.
