22A 22D Pinion?
TX
RE: 22A 22D Pinion?
is it 10t, 8t, 12t or more? I know main gear is 64pitch .4 mod. I just want to know main motor pinion so i have the right head speed.
Yes, how many teeth are in the main motor pinion gear.
RE: 22A 22D Pinion?
The 10 will be about right for brushless 12 and 14 are a bit fast. If you run brushed start with the with the 12 and go from there you can allways change it later.
