walkera #36 brushless motor help asap!!!
HI avery one this is first post i got raptor G2 which is all most the same as walkera 36 well it looks good but it can t fly so it have my self in little dilema or situation where i neeed to upgrade every thing!!! i whant to upgrade to brush less and just whant to know if any body know if this motor will fit and if the 25a
http://www.helidirect.com/product_in...oducts_id=1460
thanks for any help in adv...
ME
RE: walkera #36 brushless motor help asap!!!
well I have the same heli as you do. Go to the forum for this heli in the beginers forum. I put an align motor with esc. it is a 100$ setup but it is awsome
IL
bigNspeed21,
Unfortunately, the smallest pinion you can get for a 3.17mm shaft is an 11-tooth...with that 3500KV motor the headspeed will be way too high! I bought the JGF 450TH...it is a 3000KV and works nice on the 36. Do yourself a big favor, though - don't buy anything but the Castle Creations Phoenix 35 ESC! Some of the other ESCs won't even start these outrunners, but the Phoenix seems to work fine.
ORIGINAL: Orion1024
bigNspeed21,
bigNspeed21,
Could you tell me where you are able to get an 11 tooth pinion for the 3.17mm shaft? I have been hunting around for quite a while now and i am stuffed if i can find one.
Hope you can help
Ceers guru
IL
guru101,
Have you looked at the Align pinions? I got mine from Helidirect...it was part of the 3-pack with the 11, 13 and 15 tooth pinions. They have the set screw and my motor has a smooth shaft, so I just put it on with some Loctite 680. I had the same problem trying to find an 8T for a 2.3mm shaft...they don't seem to exist...a very good reason to stay away from those high KV motors.
http://www.helidirect.com/index.php?cPath=78
thanks for the quick asnswer but today i run in a next problem turn on my tx and reciever and notting happend recever light blinks and gyro lights also am about to toss it out the window!!![:@] can some help whit that please!!!
IL
bigNspeed21,
Do the servos work and it's just the motor that's not working, or do you mean nothing at all works?
ORIGINAL: Orion1024
guru101,
guru101,
well servos do make some movement when i connect the bat to the heli !!! but is like the transmiter is death!!! lights blink on gyro and rece!!!
Hi, sorry to deviate off a little but is 3025 rpm ok for a walkera 36 with full metal upgrades? because i have just ordered a 4200kv motor with a 10t pinion but dont know if it is too powerfull because i have already toasted 2 walkera 3200kv motors. thanks
ORIGINAL: davenraithatha
guru
