help for choosing the right heli
hi guys,
i am pretty new to this hobby and was playing around with a Solo Pro2 until it keeps breaking down without really crashing ...
so i am thinking to switch to walkera and thinking if i should get the CB100 or 4G6 which the shop recommends saying that i should purchase 4G6 since CB100 will probably get boring very soon ... having doubts to fly the 4G6 as a newb so wanna check out if you guys can help??
cheers.
cheers.
RE: help for choosing the right heli
As a newbie a CB100 will help you moving on up the ladder, the 4G6 will cause you nothing but frustration. The CB100 is much like my 4#3B double brushless, a wery good heli for beginners. The 4G6 is harder to fly than a t-rex 450. Just remember with double brushless walkera's, they need minimum 400mah 20c batteries. The original 400 10c is no good. Just my experience, for what it's worth. Keep on flying!
hi rofla,
thanks for the tips ... but can the heli take the 2C current? i am assuming that 2C refers to current right??
cheers
cheers
The heli uses the power it needs!! Double brushless solutions uses more power, therefor it requires batteries with higher C-rating to get enough power to work properly, and not to destroy the batteries. It is too low C-rating that is a problem, there is no such thing as to high C-rating. And, it is 20C, not 2C. Hope tis helps.
