Weatronic and long servo leads
Just finishing a 4 servo wing glider and wondered if Weatronic needs the iron rings to wind the long servo leads through (chokes?).
Norman Carter
ps Looking forward to the BAT 64 tray Tx
Norman Carter
It was more of a problem in the MHz days as the long servo leads were a good length for a MHz aerial, allowing the rf to feed back into the power supply and perhaps cause problems in the rx. Servo leads are not a good length for a GHz aerial so it tends to be less of a problem and the choke is not needed.
However, some people with spark ignition engines quickly found that they got interference with 2.4GHz! How can this be since we are told that sparks don't radiate as high as 2.4GHz? The problem was often traced to the long servo leads picking up the spark rf and feeding it to the servo, and a choke at the servo end of the lead rather than the rx end, cured the problem. The root of the problem though tended to be poor or broken shielding on the spark plug's HT lead.
