BAT60 trainer mode
BAT60 trainer mode
Hello,
I would like to know if it's possible (and easy) to train a student pilot with dual control on a weatronic Bat60.
I didn't find trainer mode in the menus of my Tx.
I guess it would need 2 transmitters and maybe a wire ?
Or with wifi ?
If you can help me...
Thank you.
Or with wifi ?
Thank you.
Yes, it is implemented with v6.08
You can do wireless student/trainer mode by using a TINY5 at the trainer BAT6x. It must be bound to the student BAT6x, set to sum signal output (12ch). The sum signal output of the TINY5 is then connected to the PPM input of the trainer TX. The TINY can be also powered via USB from trainer BAT6x USB port; no extra power supply required.
reagards
Thomas
reagards
Thomas
