Error message
My Feedback: (82)
Error message
Hello, I am new to the Weatronic system, and I just finished binding my micro 8 to the Tx module. On my Tx module, I can see 4 red flashes, but I do have a solid green light on the Tx and Rx. The servos do not move. Does anyone know what is going on? Thanks in advance
OR
RE: Error message
Hi iflytailies,
The solid green tells that the link between the transmitter module and the receiver is OK. The 4 red flashes indicate that the transmitter module is missing the signals from the transmitter adapter module. This is usually that the transmitter is not set to the correct mode or does not have the correct software version as can be the case with Multiplex Transmitters. I hope this helps,
Gerhard
Gerhard
