If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 11 of 11
  1. #1
    Join Date
    Feb 2007
    Wisconsin Rapids, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    28% Extra 300 Rebuild, also in need of parts.
    Unbelievably this last spring when I pulled my Extra 300 (my absolute favorite airplane) out of mothballs for the summer flying season I discovered that a couple of mice had managed to infiltrate my basement and tried turning my Extra into a new home. They did an incredible amount of damage literally chewing up over half of all the balsa on the bottom of the fuselage, and scratching off a good portion of Styrofoam down as well. They also urinated on the fuel tank deck to where plywood started to swell and the layers separate.
    I have cut out all of the damaged balsa and meticulously removed any damaged plywood. I’ve also stripped and disinfected what remains (which isn’t much) and have started painstakingly rebuilding my Extra.
    I’ve also decided to go all out with rebuilding it making sure all the seams are perfect, building as light and strong as I know how to make it, and then also decided to convert it from an Extra 300L two seat’er to an Extra 300S single seat’er and build up a more scale looking dash with instrument decals.
    I’m also in need of some parts, I need landing gear fairings, wheel pants, and a 13mm carbon fiber tube for the elevator. Can anyone help?
    Most sincerely, Thanks
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1656739   Click image for larger version.
ID:	1656740   Click image for larger version.
ID:	1656741   Click image for larger version.
ID:	1656742   Click image for larger version.
ID:	1656744   Click image for larger version.
ID:	1656745   Click image for larger version.
ID:	1656746   Click image for larger version.
ID:	1656747   Click image for larger version.
ID:	1656749   Click image for larger version.
  2. #2
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 28% Extra 300 Rebuild, also in need of parts.
    Repairs are progressing. Does anyone happen to know what the V2 Extra300 weighed by itself? I am meticulously trying to rebuild mine doing everything I can to keep the weight down but I don't have a base reference. Can anyone help?
ID:	1663698   Click image for larger version.
ID:	1663699   Click image for larger version.
ID:	1663700   Click image for larger version.
ID:	1663701   Click image for larger version.
  3. #3
    rctom's Avatar
    Join Date
    May 2002
    Flower Mound (near Dallas), TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As I recall the components that came with the plane weighed between 10 and 11 lbs, but that's from memory and could be wrong.
  4. #4
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rctom
    Most sincerely thank you Tom.
    I'm trying so hard to keep the weight down with the repairs. I have a carbon fiber wing tube and replaced the elevator stab tube with carbon fiber. I'm also thinking about switching to carbon fiber landing gear just to save on weight. I'm even grinding away any excess epoxy from the glue joints. I just hope that I can make the 11lb limit.
    Thanks again Tom!
  5. #5
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rctom
    Again thanks Tom, everything in the picture below weighs in at 8.9 pounds leaving me with 2.1 pounds to finish the plane with which makes me feel a lot better.
    Again, Thanks!
  6. #6
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have brand new landing gear fairings that mount to the gear next to the fuse.
    Smooth, like Keith Stone.
  7. #7
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mrbigg
    Thanks! I sent you a pm.
  8. #8
    rctom's Avatar
    Join Date
    May 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't get PMs. Why not just call me? 817-430-0107 or email tom@wildharerc.com
    TF
  9. #9
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rctom
    TF
    Sorry about the confusion Tom, I was replying to Mrbigg's post. He has a set of wheel fairings that I can use.
    I'll definately be emailing you if I have any other needs.
    Again, Thanks!
  10. #10
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Things are progressing, completed the muffler tunnel lining it with 1/32" plywood to keep any future mice from potentially getting into the plane (along with a whole lot of mouse traps around my storage area). So far I'm up to 9lbs, 7ounces leaving me with 1lb, 9ounces to finish the rebuild. Might just have enough weight allowance for a smoke pump.
ID:	1668456   Click image for larger version.
ID:	1668457   Click image for larger version.
ID:	1668458   Click image for larger version.
ID:	1668459   Click image for larger version.
ID:	1668461   Click image for larger version.
ID:	1668462   Click image for larger version.
ID:	1668463   Click image for larger version.
ID:	1668464   Click image for larger version.
ID:	1668466   Click image for larger version.
  11. #11
    mrbigg's Avatar
    Join Date
    Oct 2004
    Streator, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looking good.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
