Got my 28% WH Extra 300LX!- Now, Build Thread
#76
RE: Got my 28% WH Extra 300LX!- Now, Build Thread
The damage to the botton of the plane was about a seven inch tear in the covering and a broken stringer. No damage was visible on the box. I called Tom and he offered to exchange the fusalage ( which I thought was awfully nice ) but I asked him to just send me about one square foot of red covering and I would do the repairs. Two days latter I received tree square feet of covering from Tom (that's great service) and made the repairs. No big deal. The plane flyes great. Tom
#77
OH
Err, let's get back on subject shall we?
As of about an hour ago, this plane has been flown! It went well. Of course, I had quite the nervous sweat going, but as it turned out, I shouldn't have worried. After checking linkages and control throws for about the 100th time, I taxied out to my "runway" (deserted country road) pointed her straight down the yellow dotted line and fed in a little throttle. It tracked very straight and waaaay earlier than I was expecting, she just sorta levitated off the ground, it was the oddest feeling. Man this this has light wing loading! I climbed up a couple hundred feet and settled into an orbit while I checked trims. A couple beeps on the aileron, a beep of elevator, and it was hands-off. I did a couple rolls and loops, suggested low rates are a bit low for my tastes, but that's better than being too flighty.
I clicked up to high rate aileron and rudder, and started flying the IMAC basic pattern type stuff. Even on high rate it was pretty smooth. My favorite, a humpty with point rolls on the way up and down, was easy, the downline was nice and slow. After buzzing around doing the aerobatic stuff I decided to try some 3D. NOT! Are you kidding me? Actually I pointed up 45 degrees, rolled inverted and checked the balance- Nose heavy. That's good! It means I can pull my ballast back some and try again... hopefully I can remove it totally at some point. Then I did a few extended verticals to check tracking, she veered a little left so a click or so of rudder took care of that. Then my timer went off, I did a few practice approaches, then came in for the real one. That big 23-8 prop slowed it right down, a little flare and she settled onto 3 wheels as gently as can be. Total air time, 10 minutes, total runtime, 12 minutes. 12oz of fuel used. The DA ran perfectly. A quick check of everything, nothing fell off, all is tight, etc.
As I think I mentioned at the beginning of this thread, this is only my 2nd gasser. My first is a WM Patty Extra, which I now have around 100 flights on. I think it is a really good plane. The million $$ question then is: Is the WH better than the WM? Well of course it isn't- yet! I have only 10 minutes of flying on the WH! However, I can already tell that the WH has much better potential, and I find the 3D potential really exciting. I flew my WM right afterwards, and it felt like a brick! A straight-flying, smooth brick... but still a brick.
My only complaint: The Slimline pitts muffler is far too loud. It's like having no muffler at all.
All in all, I'm a pretty happy camper at this stage. More to come in future days as I get used to the plane.
#79
TX
And they are quieter.
We have them in 2 versions, 3/4" outlets and 7/8" outlet, the former for quiet and the latter for power, you choose. I think both models are quieter than slimline.
TF
#80
OH
I will check with you on these quieter mufflers one of these days... gotta do something before the neighbors shoot the plane down with rifles.
Last installment on this thread. I have 12 flights on the plane now, and am enjoying it quite a bit. I have the cg moved back to where it is almost hands-off inverted, just another 1/8" or so back and it will be perfect for me. It is not what I would call twitchy flying even with the cg back almost 1/2" from the max recommendation in the manual. I think the engine needs just a touch more right and down thrust so I will shim that next time I have the cowl off. The DA is getting broken in and starting to run richer with every flight so a little more needle tweaking is needed and then it should be perfect.
The power-to-weight on this plane can only be described with one word: RIDICULOUS! <lol> It hovers at a very low throttle setting, and will blast off out of full-stall moves with only half throttle. I hate to say it but it is almost *too much* power, it is harder to fly the IMAC stuff but I am getting used to it. This plane encourages 3D flying, it is like a gigantic Ikarus Shock Flyer.
As you may be able to tell I really like this plane. It is still not as smooth of an IMAC-type flyer as my WM Patty but it will just take more stick time and tweaking. If you are relatively new to gassers, like I am, my opinion is do not be afraid of a plane like this. It is a *****cat on low rates and with a 3.0" cg. It takes off totally straight and lands nice and easy. I can't think of a whole lot I would change if I had to, other than I would source my own hardware instead of buying the kit. Just my preference is all. I hope I don't have to for a long while, but I'd buy another one of these planes. Thumbs up.
