WH edge 84 inch
My Feedback: (52)
WH edge 84 inch
I'm working on hovering my edge with my DA 50. It seems to me like I have no responce from my rudder and elevator like I'm used to from other planes. I'm spinning a Menz 22-8 prop. It's my first bigger plane and gasser. Why does it feel like it's not responding when I'm on high rates with max throw? Do I have to blurp the throttle to get responce with these bigger planes? Any help would be great from anyone that knows.
Thanks, Scott
Thanks, Scott
MA
RE: WH edge 84 inch
id recommend a 23x8 prop then you will notice a big difference i'm using a nx prop from TBM its like night and day.also what servo's are you using?
RE: WH edge 84 inch
depends on weight if heavy you may need to burp for 3d to get responce and also how much air flow past the control serfaces a bigeer prop and lower pitch is what most use and most top pilots use throttle to expodential movement pus look at your cg further back the better but not too far
RE: WH edge 84 inch
Another question, how much "expo" are you using? If it's above 75 or 80% you won't obtain much control motion until you start making severe stick inputs. The next question is are you certain that you are actuall using high rates? The reason I ask is my experience with both the 28% Edge and Extras has been that the rudder and elevators are extremely effective even at low rates. For those reasons I'm guessing the problem is with the radio set up or a condition/mode switch position.
My Feedback: (29)
RE: WH edge 84 inch
I get my NX props from www.airwildrc.com ,,, I got my NX23x8 prop for 33.00 shipped,,,,,
