Need SuperSport parameters
Hi guys, who has a parameter set for a Wren SuperSport running a V06 ECU?
I got the parameters from the old version ECU but it is not so easy to just transfer them in the new ECU, some older parameters are in points, the new in units, different parameter names etc...
I got it running on the bench but the startup needs some tweaking, it puffs on fuelramp and I don't know why.
I need:
Pump start point
Pump start ramp
Start GAS adjust
Starter Power at ignition
Ignition MAX RPM
Ignition Min RPM
Preheat 1 time
RPM GAS OFF
Starter Power at fuelramp
RPM 100% starter power
RPM OFF starter
RPM to reconnect starter
Thanks, Bart.
I need:
Pump start point
Pump start ramp
Start GAS adjust
Ignition MAX RPM
Ignition Min RPM
Preheat 1 time
RPM GAS OFF
RPM OFF starter
Thanks, Bart.
