Wren 54mkII
My Feedback: (39)
RE: Wren 54mkII
Steve,
I had replied to your earlier email. The answer is Yes...but you indicated that this was a kit built motor, and I replied that if you built the motor, I would suggest that you send me the compressor and turbine-wheel assembly. I will install a new bearing on the shaft and rebalance, and return this along with a new front bearing and compressor.
Otherwise, please send me :
Motor
pump
ECU
Battery
Best regards.
Ron
Motor
pump
ECU
Battery
Best regards.
Ron
RE: Wren 54mkII
Hi Ron, I have a Wren 54 manual start and I like to update to automatic start, can you do this upgrade?
I live in Chile but I can send it to USA.
Best Regards
Best Regards
