Wren SS / 100 PIPE
Wren SS / 100 PIPE
Hi Ron, wondering about the dimensions of Wren's Supersport / Wren 100 pipe.
I might need to replace my old pipe, and here are the dimensions: Outer wall of my current dual walled pipe is 77mm diameter and it's 660mm long total including the bell mouth from front to end.
1) Does the 620mm pipe Wren sells have the ability to be a tad bit longer with what appears to be an exhaust end add-on, shown in the pics on the web site (below)?
2) What is the diameter of the aft end of the exhaust pipe, in mm?
3) Also, is the bell mouth removable for installation?
My Feedback: (39)
RE: Wren SS / 100 PIPE
Eddie,
The pipe can be made longer
The bellmouth is installed and spot welded at the factory
The small add on is what we refer to as the "cookie cutter". It fits over the outer pipe and centers the pipe at the rear .
Let me know the dimensions you require and I will contact Wren in England for price and availability.
Best regards,
Best regards,
Hi Ron, if you have one of these "Wren Pipes" in stock is there any way to measure the diameter of the pipe at the far aft end (exhaust side)? I'm mostly curious about that measurement as for the pipe itself, I'm limited by some size constraints - larger than a certain amount due to my scale airframe and I might have to go with another type of pipe. Thanks very much!
