Wren Turbines USA Wren USA no longer providing support for their turbines. We are converting this forum into a member supported support forum. This means members will solve members problems
Wren 54 catastrophic failure
Reply
Old 04-05-2010, 07:14 AM
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wren 54 catastrophic failure
Had a couple of flights yesterday with my Wren 54 Mk2.5 powered Boomerang and on the third flight just after takeoff at about 100ft there were sparks out the back and a bang.
I got her landed ok and when looking at it passing me by, I seen some flames so had to give it a blast with the fire extinguisher when landed luckily no airframe damage other than a bit of black burning, heat resist paint worked !
First inspections showed the tailcone twisted out of shape and the turbine wheel missing blades.
When I stripped it, I discover that the collar on the NGV end of the shaft tunnel and broken off, I had though it may have been a bearing failure but the bearing was still intake as can be seen in the picture of the shaft and turbine wheel. The broken off collar can be seen still on the shaft behind the bearing.
Damage, shaft tunnel, bearings, turbine wheel, NGV, compressor wheel, intake, tailcone, EGT probe will email wren to see what it will cost to fix, might not be worth it.
Anyone got and spares lying about ?
ID:	1412213   Click image for larger version
ID:	1412214   Click image for larger version
ID:	1412215   Click image for larger version
ID:	1412216   Click image for larger version
ID:	1412217   Click image for larger version
ID:	1412218   Click image for larger version
ID:	1412219   Click image for larger version
Xairflyer is offline
Old 04-05-2010, 08:30 AM
Turbotronic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wren 54 catastrophic failure
Seems the collar fracture is typical metal fatique introduced by the very sharp machined edge for the oring slot. Could do with a radiused tool in that machine operation. Basic engineering really. Much like the DH Comet windows...
Andre Baird
Turbotronic is offline
Old 04-06-2010, 11:57 AM
snatch-it
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi,
i had a mk3 54 that did that aswell, mine went while i was maidening my t45.
was doing a fast lowish pass when it went, managed to get in down in 1 piece though.
it had about 7.5 hours running on the clock, when i sent it back for repair it came out as an unecononical repair,
found out that the turbine wheels have been changed slightly to stop the blades from flexing and breaking.
needless to say wren did me a real good deal on a super sport, i still have wrens, at the moment ive got a 44 in a amd hawk.
a new 70 in a rafale and the super sport is now on a trusty kangaroo! also owned a few tha ive sold with models,
im sure they will be able to fix her up again, by the way the new wheels have wren wren on them, not wren 54,
hopes this easies the pain,
cheers
snatch
snatch-it is offline
Old 04-06-2010, 12:25 PM
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: snatch-it
hi,
cheers
snatch
I will wait and see what the bill is for the parts as I will rebuild it myself.
What weight is your AMD hawk I have one I was about to fit the wren 54 into
Old 04-06-2010, 12:43 PM
snatch-it
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi
the hawk weighs in at a tad over 10lbs dry, it carries 1.2 liters of fuel.
this is my second one, the first one had a 54 in it and it came out heavy, it was a bit naughty at times due to the higher wing loading.
replaced the 54 with the 44 and it turned into a different plane to fly, a good mate of mine has it now,
if you go onto google video and type in thrust productions you will see a video of it with the 54 in it. goes very well!!
hope this helps,
cheers
snatch
Old 04-20-2010, 06:21 AM
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not having much luck with getting bits from wren other than NGV, surprised they don't stock parts for a Mk3, I'm sure there are plenty of them still around, will they soon stop stocking spares for a MK4 ? something I would consider before buying a new turbine in the future.
Anyone know what the Garret part number is for the 12 blade compressor ? or have one lying about.
Also I am looking for a turbine wheel new or second hand, I might make a tunnel or buy one from JetJoe which is exactly the same.
The front intake looks to be ok, the compressor blades must be a softer metal as they have wear on them but the intake looks to have been touched by the compressor but no un-evenness or scores. Would know better with a new compressor.
I have cleaned up the marks caused by the turbine wheel on the NGV mainly rubbing against the stators,, need to check shaft, so if I had a tunnel, turbine wheel, compressor, tailcone and a new set bearings, I could rebuild it again.
Old 04-20-2010, 06:45 AM
Wren Turbines USA
My Feedback: (39)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sent you a PM.
Wren Turbines USA is offline
Contact Us Archive Advertising Cookie Policy
