Xicoy ECU on Wren 44 which PC Software ?
Gents,
which PC Software do I have to use on a Xicoy ECU V10K to read out settings and data and where do I get it ? I only found a FADV5cinst.zip file. Not sure whether this is the right one. Cheers, Ralf |
RE: Xicoy ECU on Wren 44 which PC Software ?
The FAD 5 is the correct program. You wll need the newer data cable that uses the 3 pin JR type connector. Also...the program will not run on Vista!
Ron,
thanks for the info. I do have the cable, will give it a try on a XP system. Cheers, Ralf |
