New EXI450 CNC/Carbon Edition w/ FREE Aluminum Carrying Case
CA
EXI T-450 SE Carbon Fiber Aluminum Alloy ARF Electric Mini Heli w/ 325 Fiber Glass Blade w/ Free Aluminum Carrying Case. This product arrived with 100% pre-assembled. It uses a all Carbon Fiber Main Frame, Fiberglass Main Blade, Aluminum Tail Boom, updated Aluminum Rotor Heads, Fiberglass Canopy and is designed and equipped to be capable of the most extreme 3D maneuvers . And since this kit is 100% assembled, you can have it flying in just a few hours.=
Features
New CNC Carbon Fiber frame, improve the rigidity and perfect for 3D flying.
FiberGlass Canopy
CCPM version, new aluminum parts for prompt, precision actions.
New longer 3K battery mounting plate connects to main frame. It makes the center of gravity closed to rotor blade, and can adjust the center of gravity according to the weight of battery, it reduces the correction when the heli rolling.
Rigid CNC aluminum rotor head for precision and smooth movements.
Tail rotor hub made of stainless steel, very rigid.
Use 35pcs precision bearing.
Great stable and sensitive mixing lever design! Can display the great stability and precision for 3D flight.
Special adjustable pitch system, hold rotation system, tail rotor drive belt system! It is a work of great originality for helicopter!
Using new CNC Metal Main rotor holder with thrust bearing and 4mm Feathering shaft, features smooth rotation and stability under high rotation speed.
Using Ball and Hiller two systems mixing control. Through simple structure of Ball control system, power-saving of Hiller system and CCPM control, can simultaneously control 3 servo for AILE, EVLE, PIT 3 actions. This CCPM control system is great for 3D flying control and extending life cycle of servos.
New c.g. amended tail blades feature streamlined and quick, make the gyro more efficient.
Tail rotor control set with dual bearing, features CNC control piece and smooth structure design, get smooth pitch travel.
Providing flybar weight- When normal flying, you can add the weights on flybar paddles for stable flight.
When aerobatic flying, you don't need to add the weight, but you can see the flexibility of 3D actions.
CNC tail pulley assembly and tail holder are using high rigid aluminum alloy, features wear resistant and falling resistance.
New gear ratio(4.24:1), suitable for the motor with higher KV, provide more safety.
Using new high strength ball links and stainless steel linkage balls on the whole unit, feature wear resistance, anti-oxidization.
Specs
Length:660mm
Height:230mm
Main Blade Length:325mm
Main Rotor Diameter:700mm
Tail Rotor Diameter:150mm
Motor Pinion Gear:12T/13T
Main Drive Gear:150T
Autorotation Tail Drive Gear:106T
Tail Drive Gear:25T
Drive Gear Ratio:1:12.5:4.24/1:11.5:4.24
Weight (w/o main blade):450g
Flying Weight:Approx.730~760g
Features
FiberGlass Canopy
Specs
Length:660mm
Height:230mm
Tail Drive Gear:25T
