XHeli.com Support Forum If you have a question, problem or concern about your product from xheli.com, please use this forum to get answers to your questions.
Dynam E-Razor 450
Reply
Old 05-06-2011, 09:27 PM
  #51
HersheyP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dynam E-Razor 450
Hello All,
Just bought Dynam E-Razor 450 Carbon Fiber Edition.
Comes with Carbon fiber frame main blades, boom, tail blades, upgraded high performance head lock gyro (GY48V), and full aluminum alloy upgrade, 2.4 gig Tx.
Okay first time order from XHeli,
1. Main blade was damaged upon receipt (Xheli replaced)
2. Blade tracking was off. One blade had a higher pitch than other. Adjusted by watching you tube videos on blade tracking.
3. Rear servo not properly mounted causing rudder to get stuck on side, servo making noises and getting hot, heli rotating uncontrollably trim not helping. This is the fix I used: http://www.rcgroups.com/forums/showt...7#post18169314 The rudder still stops and stay on either side if i push the stick all the way to one side. But the servo at least stops and doesn't try to keep moving so now it doesn't get stuck, no servo noises and no over heating. Also if I flick the joystick in opposite direction it does re-center the rudder making it flyable now.
4. The Battery is taking to long to charge first charge after first flight took 4 hours to charge a 11.1V 2200mAh 20C battery, charger is 1.0A.
Xheli says that's normal. Which I can't believe to be true because the manual states 1.52 hours max.
5. The FMS simulator was not so helpful because the 6ch controller it comes with doesn't really have a NOR/3D switch. How can you tell how the flight characteristics is will change in real life when flipping that switch if the simulator doesn't have anything like that?
I really like the Heli but just wish Dynam had a better QC department and wished Xheli had better tech support.
P.S. can't really find any how-to-videos or posts on adjusting the pitch and throttle curves in nor and 3d mode for the 2.4GHz  Transmitter(Tx). Can anyone help?
Hershey P.
HersheyP is offline
Old 05-07-2011, 12:01 PM
  #52
HersheyP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello All,
Update to me pervious post on point #3. Rear servo and rudder control after reading this Review on the Dyman E-Razor 450 I learned that my Rudder mixing on the Tx was actually on which you don't want when using a Heading Hold gyro. So following the instructions on:http://www.mycoolheli.com/reviews/ReviewERazor450.htmlI turned off Rudder mixing (revo mix) seem it was on partially. Now its completely off finally when I move the left joystick right and left the rudder moves right and left and then goes back to center. Only stays to one side if you keep holding the joystick to one side. Yea! problem completely fixed.
Thanks to all the forums and mycoolheli.com!
HersheyP is offline
Old 06-18-2013, 03:26 AM
  #53
rajeshbhanushali123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello every one,
I have Simulator cable comes with Fly Sky 6-ch radio.
but now i have Dynam 6-ch radio
http://www.dynam-rc.com/products/tra...r/2.4G-6ch.htm
These both are compatible?.
if yes i am not able to use radio as simulator on FMS even my pc is not detecting radio.
can anybody help me out
rajeshbhanushali123 is offline
