XHeli.com Support Forum If you have a question, problem or concern about your product from xheli.com, please use this forum to get answers to your questions.
G2 questions.
Reply
Old 12-31-2009, 09:40 AM
rob_acdgspetc
rob_acdgspetc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default G2 questions.
1. Someone had said thier G2 wasn't powering up when plugging in the battery and you stated " The radio system you have is made by walkera so a special attention is needed here. To start, you must connect the battery to the heli first. Put the left joystick down and then to the right of it, put the speed trim down. Then turn ON the radio, move the right joystick in a circular direction to trigger the bind." I just want to be sure there's no danger of the heli starting up when doing this. I've had the same issue, but I've just been unplugging and replugging the battery and it seems to work.
2. The video on the website says that on the radio the switches and knobs don't mean anything, however the instructions say the left button turns the heli to 3D mode once the throttle is at 50%. What's what with this and what, if anything, do the any of the other switches or knobs do?
3. I am using the Clearview sim. Is there a way to conect my transmitter to my computer to use with the sim?
Rob
rob_acdgspetc is offline
Old 01-06-2010, 08:35 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: G2 questions.
1. If your radio fro the g2 is the 2.4Ghz then you must connect the battery to the heli first. The 2.4Ghz has a protection function. If you connect the battery to the heli first without the radio ON, it will not go into full power. If you want to play it safe you can disconnect the motor to the ESC when you try this procedure.
2. You 3d idle switch is on the right. The left knob is for adjustment of hovering pitch and the right know is your adjustment for the pitch of the heli.
3. Yes you have to buy a sim adapter from walkera to do this, which we do not sell.
Andy
yadac123 is offline
Old 01-07-2010, 08:04 AM
rob_acdgspetc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Andy.
Old 01-11-2010, 10:58 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Andy
yadac123 is offline
Reply
Display Modes
