No motor power dynam 450
MS
Hi, for some reason, I have no motor power when I give it throttle... Collective just changes... What should I check out first?
RE: No motor power dynam 450
I recently bought the Dynam 450 from Xheli. It had been flying okay and it had a minor crash in my garage where nothing was visably damaged. After I tried flying it after the spill it no longer would take off. It would just spin up and then tip towards the left. After closer inpection it appeared that 2 of the servos were not responding. I ordered and replaced the servos from Xheli and the issue still exists. After closer inspection it appears that the tail server is not working either. The crash the heli had was not a significant impact. Is this a symptom of the bad electronics that many have suggested the ERazor is sold with? Any thoughts on what is going on? Is it the receiver? I noticed that Xheli does not offer those on the spare parts page for the heli.
Any help would be appreciated as I would like to get this thing back in the air...
My Feedback: (14)
I ran the servos on mine for about 60 flights, had the tail gyro go bad. so i just replaced it and all the servos with carona 929mg's made a lot nicer flying heli out of it. the stock dynam servos are not very good at all oh order a set or two of the main and pinion gears for spares.
