Recommended tank size
My Feedback: (58)
RE: Recommended tank size
8 oz from the factory for a 60-91 sized bipe? I use 12 oz usually on my YS 91 powered planes so I get some decent flight times. Make sure you use a good qulity tank as the last thing you want is cheap tank that wil split under pressure and soak your new plane with fuel from the inside out.
My Feedback: (41)
ORIGINAL: luckyflyer
What is a recommended tank size for a YS 91? My GP Reactor bipe came with a 23cc tank but it looks small for this engine.
I don't run any 91's but have a couple of 110's and the way I fly I can figure on about 1oz. per minute fuel burn, so I use either a 16oz. or 500cc (that's about 17oz.) on those engines.
NM
Thanks everyone, apparently my tank is 230 cc's not 23 cc slightly less than 8 oz. I maidened my reactor wit the 91 ac and for my flying style I think I'll be ok.
