YS Engines Support Direct support from YS Performance Engines by Dave Shadel
DZ170 Throttle Linkage
Reply
Old 05-08-2011, 10:40 PM
rolyjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DZ170 Throttle Linkage
Hi all,
i have been out of the game for some time now and would appreciate some advice. I have search the forum/s on throttle linkage for the DZ170, however come up with nil. My question is what is the best linkage setup. When i installed everything, i was advised to run a silicone tube "connector" between the linkage to allow for the vibration, but this is more likely to save the servo? i am running a mini servo. any suggestions or advice is appreciated.
thanks
roly
rolyjr is offline
Old 05-09-2011, 04:41 AM
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: DZ170 Throttle Linkage
I have used flexable cable with ball and socket at the throllte arm. Ive been using this for more than 15 years with no servo problems on mini servos.
I safty wire the ball and socket just for extra reliabliy.
mtcarey is offline
Old 05-09-2011, 05:31 AM
petec
petec's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That would depend on the mount and how much the engine moves. I run a mini servo with a piece of 2-56 push rod with a Hyde mount and a nose ring. The engine doesnt move enough to make a difference.
I had another soft mount type in an ARF that would eat servo gears because there was no nose ring and the engine moved around. If it kicked back hard the servo gear was toast so in that case the piece of silicone would have been helpful.
petec is offline
Old 05-09-2011, 09:33 PM
rolyjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, thanks for the responses. i am also running a hyde mount and nose ring so in theory i should be ok if it works for you. i will try my tubing setup first, if i still battle with the engine cut out, then i will move to a rigid setup. all the best, roly.
rolyjr is offline
Old 05-11-2011, 06:23 AM
apereira
apereira's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also use the flex cable from sullivan and a micro servo, the cable or a nyrod is good enogh for any soft mount, that is if you are mounting the servo far from the engine, if you are installing the servo close to the engine and does not have to go thru any bulkheads then you can use a push rod, but use ball links on that setup, on my cables I always use gold'n rods kwik links.
Regards
Alejandro P.
apereira is offline
Reply
Display Modes
