YS CDI RF interference
RE: YS CDI RF interference
I'm using Cdi on my model with a futaba 149 rx on 35Mhz. I have a seperate ignition battery and regulator just to keep it as isolated as possible, and spaced the ignition module some 12 inches away from the receiver, never had any problems.
ORIGINAL: jkruger
Has anyone had an RF interference problem with YS CDI engines when using 72MHZ equipment?
I would not fly with a CDI on 72 or or 50/53 or 35 or any HF frequency.
I used the CDI as an excuse to change to 2.4g from decades of trouble free flying on 53.
I plugged the CDI directly into the reciever with a suicide extension....it is a standard servo extension.
When at the field or when I know I am going to run the engine, it is plugged in at the CDI.
In the shop or with the receiver on at any other time.....the extension is unplugged.
No second switch, no extra batteries, no second regulator.
One thing though.....the receiver battery should have more capacity than usual because the CDI pulls a fair amount of current.
The higher the rpm, the higher the current....
I am using the Futaba 6008HS receiver with a 9zap transmitter and matching tx module.
I'm still running 36Mhz (Futaba, PCM2048 G3) and can't say I've ever experienced a "hold" let alone a failsafe lockout.
However, if after passing the ground checks the plug cap decided to make a poor contact with the plug or the braid broke away from inside the cdi unit then I'd bet money any of the 72/35/36 Mhz systems wouldn't be happy.
I use the same li-po battery for the RX regulator and the CDI regulator, and ground checks (and now many many flights) have proven it to be ok but like they say, your mileage may vary. I've got a Castle Creations 85HV that's next to unusable on 36Mhz but many others have no problems with them????
