If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Dec 2002
    Yuma, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YS 175 CDI Nose Ring
    Is the Central Hobbies nose ring for a YS 175CDI supposed to be a snug fit on the engine? The one I just got from Central Hobbies has about a 1/32 inch gap all around the engine.
  2. #2
    petec's Avatar
    Join Date
    Jan 2002
    Beaver Falls, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: YS 175 CDI Nose Ring
    I don't know about Central parts and it might warrant a call to them, but I never had a nose ring that had a gap around it and the engine.
    Team YS, Pattern Junkie
    Revver Brother #82, Gear Head
  3. #3
    jkruger,
    The 175 has the same diameter as the previous engine versions, it seems you have an nose ring wich is out of tolerance.
    Regards
  4. #4
    Join Date
    Dec 2002
    Yuma, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Talked to Central Hobbies and they recognized the problem. Has something to do with the YS soft mount and its requirement for a nose ring. The fix is to replace the rubber gasket with small fuel tubing. Central Hobbies is sending me a modified nose ring at no cost. That is service.
  5. #5
    It has to be firm, I will sugest to fill the fuel tubing with RTV, that will give the necessary support.
    I support your statement about Central Hobbies, on top of the best HS for sure.
    Regards
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
