YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YSDZ 160 cam bearing removal from crankcase
Reply
Old 09-07-2012, 05:12 PM
PeterP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default YSDZ 160 cam bearing removal from crankcase
I am in the middle of trying to remove a cam bearing from a DZ 160 Crankcase. Anyone got any suggestions how too! -
PeterP is online now
Old 09-08-2012, 04:37 AM
petec
petec's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: YSDZ 160 cam bearing removal from crankcase
I would heat the case up in an oven and holding the case with a welding glove, tap it on the side on a piece of wood to get it out. I know some guys use a torch to heat the crankcase but that would be personal preference.
petec is offline
Old 09-09-2012, 02:16 AM
XMANS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As Petec says, heating up the case normally works but sometimes it won't budge, I made up a special tool that goes into the bearing hole and I expand the end
to grip the bearing then I can pull it out of the hot crankcase.
YS Service Down Under
XMANS is offline
Old 11-18-2012, 01:39 AM
TVLmole
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Easiest way is to shave some candle wax into the bearing inner hole and tamp it in with the smooth end of a drill the same diameter as the shaft end. Keep adding wax untill full and tamp a bit harder, the bearing will be pushed out. Takes about one minute to accomplish with no mechanical damage.
TVLmole is offline
Reply
Display Modes
