YS Engines Support Direct support from YS Performance Engines by Dave Shadel
ys fz 63 break in
Old 05-29-2013, 01:09 PM
Stick 40
Default ys fz 63 break in
I am new to the YS engines, I have several Saito's like them very much.
BUT I have two new Ys engines to break in, a fz63s and a fz120.
I want to start with the 63 as I am getting a plane ready for it. Its a funtana S 40 , what prop , fuel etc. I have the instructions , but would look forward to any advice.
sticks
Old 05-29-2013, 01:28 PM
AMA 74894
Moderator
AMA 74894's Avatar
Default RE: ys fz 63 break in
I'm subscribed, Stick 40
JUST in case you don't get any replies, at least you won't be left in the dark
Old 05-29-2013, 02:34 PM
Stick 40
can't belive I will be left in the dark ( been there a lot in my life ). this is a great forum and has provided a lot of help in the past.
I general break in with castrol oil fuel, but some have said 15% Nito seny would be alright for break in. I have some 15 %nitro and could add some caster oil to it, but that would drop the nitro by volum?
Old 05-29-2013, 03:14 PM
Stick 40
The funtana s 40 comes with a 11 oz fuel tank, sounds a little small for that engine????
sticks
Old 05-29-2013, 05:03 PM
petec
My Feedback: (58)
petec's Avatar
I'm always in the dark too.....small world.
To begin with I would not suggest using 15% nitro until you become very adept at tuning a YS. The nitro is an oxidizer and higher nitro content gives you a wider sweet spot for tuning, which is something you definitely want since you are new to YS and breaking in the engine and it is going to drift a bit in tune anyway. Get yourself a good known brand of YS 20/20 mix fuel or use what a LOT of guys swear by which is the Cool Power 30% heli fuel. Get a spare YS #4 or OS type F plug or two in the event you have a plug go south on you. Trust me when I tell you using any other plug will ruin your day....I learned that the hard way.
Prop, an APC 13x6 would suit you well for break in and general flying. Then just follow the directions. If you have any other questions post them here. If someone does not get your question answered just PM me and I'll make time to get you answered. but there are a bunch of good guys who answer questions here and I am VERY happy to have them here to help.
Old 05-29-2013, 05:27 PM
Stick 40
Hi,
thanks
I will get the fuel, I have one F plug will get more. I enjoy working with our engines and look forward to flying this engine.
sticks
Old 05-30-2013, 06:30 AM
petec
My Feedback: (58)
petec's Avatar
Check out this link as well:
http://www.julton.net/Fact%20Sheet%20YS%20Engines.html
Old 05-30-2013, 06:34 PM
Stick 40
yes, went there and printed it looks very good.
when they are talking about max rpm of 10,500 to 11,500 , is that on the ground? I generaly set my saito's to about 1K under max so that they can unload in the air and still be under max.
thanks for the info.
sticks
Old 06-02-2013, 08:20 PM
Jimmy Skids
Jimmy Skids's Avatar
ORIGINAL: Stick 40
If I may add. I would not recommend the use of castor with a YS. Go with Petec's recommendation of cool power and you will be happy.
Jimmy Skids
Old 06-03-2013, 08:09 AM
petec
My Feedback: (58)
petec's Avatar
That is ground RPM and I usually only back mine off about 500 RPM.
Old 06-09-2013, 04:05 PM
Stick 40
yes, I have got that idea, 1 K is too much.
I have the 30% cool power heli fuel, I was going to bench run it. But have changed my mind, and will break it in the air a little rich.
thanks again for all the help, this is a nice engine and I want to do well with it.
sticks
