Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Manufacturers Direct Support Forum > YS Engines Support
Reload this Page >
185 dz cdi - air in the fuel line between injector and throttle body
YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Old 01-12-2017, 07:11 PM
topiwala
Unhappy 185 dz cdi - air in the fuel line between injector and throttle body
Hi guys,
Not sure if this is even an issue or not. But I have noticed air bubbles appearing in the fuel line between the injector and the throttle body. While the engine doesn't seem to be complaining, some how I don't feel this is normal.....
The bubbles set to be forming from inside the throttle body, and appear when the engine is at a high power setting, not at idle. At a high power setting and up to full throttle, the bubbles continue forming and travel up to the injector.
There is no air passing from the regulator to the throttle body.
I don't think that I have seen this on my earlier DZ cdi's (170, 175 ETC).
Does anyone have any insights as to whether this is an issue?
RGDS
Mayur
Old 02-19-2017, 01:15 AM
Alprausch
Hi,
I found a thread which could answer your question.
http://www.rcuniverse.com/forum/ys-e...fuel-tube.html
