YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 140 DINGO how set the gap disc valve?
Reply
Old 05-05-2017, 05:59 PM
edoardoaudio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default YS 140 DINGO how set the gap disc valve?
hi all
sorry for my english
i have order some parts for rebuild my DZ140, piston ring, crankshaft ring, front bearing oil seal, bearings, o-ring set, gasket set isulator pump.
i disassembled all engine for washing it, but i do not misure the gap from disc valve to back plate before disassemble it
now, i have a big problem!!!! how to set up gap from disc valve to back plate?. must i use the thickness gauge? how many thickness? or exist another method to set up it?
sorry
edoardoaudio is offline
Old 05-08-2017, 07:35 AM
Four Stroker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You cannot get a thickness gauge between the rotary disc and back plate. Oil it so there is an oil film in the gap and adjust it by feel. Should have a slight drag. Under no circumstances should you be able to feel any in/out play of the rotary valve on the pin.
Four Stroker is offline
Old 05-10-2017, 01:31 AM
edoardoaudio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks
Old 05-10-2017, 10:08 PM
edoardoaudio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how to mount rear bearing???
Old 05-11-2017, 06:46 AM
Four Stroker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
But the case in the oven at 250~300F and bake for 20 minutes. The rear bearing will fall out with the crankshaft.
Old 05-11-2017, 10:39 PM
edoardoaudio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i mount the rear bearing in the carter follow this method
- crankshaft in the freezer 3 h
- rear bearing heat for 60" with hot air gun
bearing mount on the crankshaft , i don't have any interference.
- i have waitinfg 30 minutes for cooler the crankshaft and rear bearing, after apply the crankshaft ring,
- crankshaft bering and ring into the freezer for 3h
carter heat with hot air gun for 60"
mount all!
thanks all
Contact Us Archive Advertising Cookie Policy
