YS Engines Support Direct support from YS Performance Engines by Dave Shadel
DZ160 won't shut down
Reply
Old 01-30-2018, 03:33 AM
TampaRCGuy
My Feedback: (282)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DZ160 won't shut down
test running a DZ160 and when the carb barrel is closed, the engine ticks over and will not stop. I did adjust the spring screw with no change. Sounds like an air leak. Where is the most common place a air leak would be?
I test ran a Xoar 17x8 prop on 15% PM fuel, turning 9,000 rpm with good transition.
Thank you.
TampaRCGuy is offline
Old 01-31-2018, 04:54 AM
d jones
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ys160
Intake nipple. Take the head off and Replace the four O rings.Problem solved !!!
d jones is offline
