YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 53 Self-Help
Reply
Old 05-07-2004, 10:20 PM
1Eye
1Eye's Avatar
Location: https://www.google.com/maps/@39.0296805,-104.8142156,17z
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default YS 53 Self-Help
I've a nicely broken in 53 that's given great service and, until recently, has always run great However lately it will not consisently hold a needle setting and any range of adjustment is considerably more narrow than it has been when it was "happy." Is this indicative of a regulator needing service or adjustment? That said, is this something I can tackle or should the engine be sent in for inspection and repair? Thanks for any suggestions or encouragement.
Mike
1Eye is offline
Old 05-08-2004, 08:10 AM
Dave Shadel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: YS 53 Self-Help
It's hard to say what the problem could be. How is the hot compression? If it leaks enough compression while it is at operating temperature, it will effect the adjustments.
Have the valve adjustments been checked?
At a minimum I would replace the diaphragm, and see if it helps.
Let me know.
Dave
Dave Shadel is offline
Old 05-08-2004, 08:16 AM
1Eye
1Eye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, I recently set the valves - in fact, I usually check them twice a year. Hot compression feels OK. Is the diaphram replacement and re-adjustment something I could attempt without messing it up? Or should I send the engine to you for ... ?
Thanks.
Mike
1Eye is offline
Old 05-08-2004, 09:38 AM
Dave Shadel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's easy to do. Just pop the regulator housing off and put in a new one. Just be sure to mark the housing as it will go on either way.
Old 05-08-2004, 12:43 PM
1Eye
1Eye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool - thanks, Dave! I'll order one up and give it a try.
Mike
1Eye is offline
Old 05-08-2004, 05:29 PM
Dave Shadel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Let me know how it works out.
Good Flying!
Contact Us Archive Advertising Cookie Policy
