YS Engines Support Direct support from YS Performance Engines by Dave Shadel
ys 110 fuel line
Reply
Old 10-18-2004, 06:35 PM
lcacing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ys 110 fuel line
what size of fuel line do i use? the tank is going to be about 20" away, also im thinking on making my own
smoke system and "t" off the pressure line and adding another check valve, would this affect the
fuel pressure?
lcacing is offline
Old 10-18-2004, 08:05 PM
bubbagates
bubbagates's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ys 110 fuel line
I once saw a diagram of doing exactly this but for the life of me I cannot find the bookmark. Once I find it I'll post it
bubbagates is offline
Old 10-18-2004, 08:57 PM
bubbagates
bubbagates's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I actually found a diagram for the version that uses a hopper tank to keep pressure available to both systems. If you can blow it up then you can really see the layout
Old 10-18-2004, 11:38 PM
MustangAce
MustangAce's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While we're at it........can I just run a 3rd "filler" tube from the tank to a dot. How do I fill and depressurize?
MustangAce is offline
Old 09-22-2009, 12:29 AM
Hardy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Set up the fuel lines as per the diagram in the FZ110 operator's manual. To run smoke use a smoke oil pump. To fill and depressure the ys system, put a tie and dot in the pressure line between the check valve and the fuel tank to depressure the system. Put a tie and dot between the engine fuel filter and the tank use this dot to fill the tank. When I finish flying for the day, I remove the the depressure vent dot and replace it with a fuel filter. This vents the fuel tank pressure and allows the tank to equalize keeping stress off of the fuel regulator system. Been doing this for several years on two different ys engines, it makes them easier to start the next time you go to the field.
Hardy is offline
Reply
Display Modes
