.63 FZ wont quit
My Feedback: (145)
.63 FZ wont quit
I have a .63 FZ that has about 1 gallon through it. It runs great at all RPMS but when I close it down it will not shut off. I have moved the throttle set screw both ways and it still idles. I also put my finger over the carb and she still runs, so I suspect a air leak.
I have replaced throttle body seal, all gaskets, regulator diaphram, plunger, and spring. When I do get it to shut off I can hear a slight air sound when I open the throttle a little bit, but I suspect this is normal with the pressure of the tank, But I also hear a slight hiss with the throttle valve all the way closed. Is this normal.
Thanks for you help.
