YS 110 low and middle problems
Hi:
I have a new YS110 in a Funtana90 and yesterday I started it for the first time. I use APC16x6, 24 % synthetic oil 20 % nitro, level of sea.
The engine started to the first return of the starter, perfectly, once warm I took it to the maximum and fitted the needle valve opening it a little bit more in order to keep it cool.
The problem comes when you take it to the idle position. The idle goes well for a seconds (2500rpm), then it starts to speed up and dies if the glow plug is not connected if the plug has power returns to recover and start again the process.
The low speed needle seams does not work because I move it in both directions and the engine makes the same. Some times I have moved the low speed valve so long that I have to start again.
Thanks in advance for your help and sorry for my poor english.
Ramon
Ramon
RE: YS 110 low and middle problems
Go to www.ysperformance.com and follow the instructions. Let me know if the running improves.
Thanks!
Thanks!
