If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 10 of 10
  1. #1
    Join Date
    Jan 2004
    Derry, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YS110 regulator issues
    Hi Dave, This forum has been a very useful tool thanks to you. I have a newly broken in engine that appears to be problematic. The top end RPM and idle at or below 2000 RPM appears good. The transition between just above idle on up to almost full RPM is extremely rich to the point of erratic to dying. Turning in the regulator adjustment makes no effect. I have followed the YS performance recommended procedure too the tee several attempts. no help. I purchased this engine last year here in the USA.
    Should I send it in to you? Thanks in advance...
  2. #2
    Join Date
    Apr 2002
    Gardnerville, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: YS110 regulator issues
    Send it. Reg is sticking.
  3. #3
    bubbagates's Avatar
    Join Date
    May 2004
    Elizabethtown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Dave,
    I had the exact same problem and pulled the reg off and found it to be sticking. I worked it loose and replaced the gasket but now it allows allot of fuel to come out of the carb when not running. I do not mean a drip every so often but anywhere from a steady stream to a fast drip which all depends if I turn the prop up to compression or not. After getting the plunger to work freely my transition improved a great deal.
    Should I also consider sending mine in or are there certain part numbers I need to know about replacing the plunger. I read somewhere in this forum that there is a plunger available that is a tad bit shorter that seems to work well. If there is do you have the part number? I can do the work myself.
    Bill James
    IMAC NorthEast Regional Director
    2009-2010
    2013-2014
  4. #4
    Join Date
    Apr 2002
    Gardnerville, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Call Richard at service-775-782-4562. He can send the necessary pieces.
    Good Luck.
  5. #5
    Join Date
    Jan 2004
    Derry, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK Dave, Thanks for your rapid response. I'm taking it out of the plane now and plan to have it sent today.
    Thank you very much!
  6. #6
    Join Date
    Apr 2002
    Gardnerville, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We will get it fixed
  7. #7
    Join Date
    Jan 2004
    Derry, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Dave, I received my engine in the mail today. Thanks! It's back in the plane tonight with plans to fire it up tomorrow. I feel like a kid. The guys at the field can't believe this online support you have provided. I got a real chuckle out of the 100% discount on the receipt for services rendered. One of the club members has a new 110 still in the box 2 month old. Should I tell him to get in touch with you?
    Thanks again for all your help.
  8. #8
    Join Date
    Apr 2002
    Gardnerville, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tell him to run it first.
  9. #9
    Join Date
    Jan 2004
    Derry, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Dave, My engine is running excellent thanks to you. If I have any other issues, I will definitely look to you and this RC forum. As for the other YS110 in the box that I mentioned, I will work with him on that.
    P.S. Thanks a million for your expedient time and attention to YS engine owners in the world of Product Support. You have proven to be first rate, with this particular example, full circle, once again.
    Sincerely Yours.
  10. #10
    Join Date
    Apr 2002
    Gardnerville, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My pleasure, good flying!
    Dave
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
