ys .63 DAVE?
ys .63 DAVE?
Hey Dave,
After running my .63 in nice and rich it has come time to adjust the valve clearance, I just opened the valve tappet cover, and there is no clearance between the valves and the tappets. I looked into the exhaust port for signs of a burnt valve and it looks ok with a bright light compression is still good and as a said i ran it nice and rich. It was running perfectly before removing the cover.
So I'll reset the valve clearance and fire her back up, unless there is anything you would adivse apart from sending it in I'm in Aus.
0.1mm is the clearance to be set, should it be hard to get the feeler in? and if i dont have a feeler is there something i can use other than a feeler of 0.1mm? and the gasket isnt damaged will it be ok to reuse?
Cheers,
Loving the engine
Will
Its been run in on 20/20 coolpower oil and nitro (home mixed)
os f plug
and a ram 12X6 prop
Cheers,
Loving the engine
Will
os f plug
and a ram 12X6 prop
RE: ys .63
according to dave whic I have copied from his earlier post "01mm would be extremely tight. The spec says .04 to .1mm. We use .003" that's INCHES, not MM." I reuse the gasket with no problem
RE: ys .63 DAVE?
You should set the valves at .003". A crisp new dollar bill would work, but I don't know how thick your money is down under
No reason to send it anywhere, just reset the valves and go!
Good Flying!
Good Flying!
