YS 45 and glow plugs
Dave; What glow plug would you suggest for a YS 45 side exhaust? I am using it in a 3d type aircraft and do not need huge speed or anything. I plan on using 15% fuel and am at around 1400 feet asl. The prop will likely be in the 11/7 to the apc 12.25x3.75 range. Thanks for any help.
RE: YS 45 and glow plugs
OS #8
others will work as well. The OS #A3
The Hangar 9 glow plugs are good also
The ducted fan plugs also work really well.
and the 2 cycle Super plugs from Hangar 9 are good choices in this engine
I have even run the OS#F or YS plug in a 45RE
Troy Newman
Team YS Performance
Troy Newman
Team YS Performance
Hello, I use in my YS 45, the spark plug O.S. Nº8, combustible Omega 15% of nitro and 18% of oil, and the APC 12.25x3.75. The motor is 5 years old, he walks perfect and never I had to change no piece of the motor.
Never it either uses it with the original muffler.
Greetings.
Greetings.
