How to tell if you need new bearings
Troy:
I've had my 110 for one season now. I have been kinda hard on it having a few prop strikes. It seems to have lost about 500 rpms or so, but I could just have it out of adjustment. Anyway, when i rotate the crank, I can't tell if the valve cam is causing an "unsmoothness" or if it is the bearings. I have only had 2 strokes before and it is easy to tell with them.
RE: How to tell if you need new bearings
probably bearings, and maybe a new ring.
If there is any rough feel to it.
Also a way to tell is to grab the prop shaft and and move it back and forth sideways. If there is any play its is time.
Usually the 4 strokes don't get worn out on the bearing they get rough. This is a sign they are bad and need replaced. Chances are the rough feeling is not in the cam gear its in the bearings if any.
Troy Newman
Team YS Performance
Troy Newman
Team YS Performance
