YS Engines Support Direct support from YS Performance Engines by Dave Shadel
What engine mount to use on inverted YS63?
Reply
Old 08-18-2007, 02:49 AM
DaveInLA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What engine mount to use on inverted YS63?
Hi, I'm thinking of mounting the older YS63 in an inverted position for a warbird (Kyosho Zero). I've heard that the older engine has a reputation for warping its crankcase using certain mounts, but I'm not clear on which type (aluminum or glass-filled nylon). Can anyone recommend a good engine mount for this engine that won't cause this problem? Is nylon better or aluminum?
Also, in case I choose the 63S model, does it use the same mount?
DaveInLA is offline
Old 08-22-2007, 12:08 AM
DaveInLA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: What engine mount to use on inverted YS63?
Nobody?
DaveInLA is offline
Old 08-22-2007, 07:36 AM
jwmm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hyde mounts do a soft mount for YS 63, also fits 63s.
Dosent require a nose ring fitting.
jwmm is offline
Old 08-22-2007, 09:30 PM
DaveInLA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does "soft" mount simply refer to glass-filled nylon, or metal mounts with rubber grommets?
DaveInLA is offline
Old 08-22-2007, 11:24 PM
Troy Newman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know of any issues with the motor mounts warping the case....I have used the nylon glass filled mounts on the 63's and 110's although on the larger engines these mounts are a little weak.
An aluminum beam style mount will be fine also....
On the larger engines I use a Hyde soft mount. These have a rubber isolator and only work in rotational movement. Its not like mounting the engine on rubber bumpers....however there are a couple of rubber bumper mounts out there that will work..
For me personally the normal mounts that come with most kits are fine for the 63's they don't shake too much.
Central Hobbies has hyde mounts and the Dave brown rubber bumper style mounts.
www.centralhobbies.com
Dave brown nylon style mounts work also.
Troy Newman
Team YS
Troy Newman is offline
Reply
Display Modes
