YS 110S crankshaft
CA
YS 110S crankshaft
The pic attached is what came with my engine. I just bought a new crankshaft and it does n't have the brass liner/insert. Does anyone know which is the improved design? with or without the brass liner/insert? reference p/n YSE 5425
Also, the front bearing was metal shield and now is the rubber seal.
RE: YS 110S crankshaft
The 110S has a different crank than the 110FZ
The 110S part Number should be 5425
110FZ is p/n 4320
It is possible the wrong part was in the bag..meaning it was mis-labeled
Contact YS Parts and Service and they can correct the problem for you.
www.yspartsandservice.com
As for Bearings
Front Bearing 110S #1050
110FZ #0695
Troy Newman
Team YS
110FZ is p/n 4320
As for Bearings
110FZ #0695
Troy Newman
Team YS
CA
It was 5425. and labeled for 110S. So, the brass liner is for the 110S. That's funny because the 110S diagram in the manual does not show the brass liner.
I will try to call Richard on Monday. Is this the same number as on the yspartsandservice website?
Like I said likely a 110FZ crank in the package of a 110S. Thus a mislabeled part.
I don't know for sure I have not had my 110S Apart. I know the crank changed. That is all I know.
Troy Newman
Team YS
Troy Newman
Team YS
CA
I called Richard and he said to send the new crankshaft to him and he will replace it if it's not for 110S. Richard said front bearing have rubber shield now.
Someone told me the bearing for below is the same:
110FZ #0695
110FZ #0695
