YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Priming 140 DZ
Reply
Old 06-25-2003, 02:41 PM
3D Joy
3D Joy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Priming 140 DZ
What is the best way to get fuel to the pump on the first start of the day? The best way I found is turning the engine with the starter for a good 10 to 15 seconds (kinda drains the field box battery in a hurry) or choking like a gas engine (flipping the prop by hand so the intake valve moves and pumps) but it is a very long process.
My tank is on the CG on a 25% CAP 232 so it is about at 10 to 12 inches away from the engine pump.
I would also like to know if it can diminish performance if I only use a tube of about 7 inches long with a simple header from central hobbies. I am wondering if it can cause some restriction and reduce performance.
This is a great engine but it seems to lack power from what I see on the net. It idles incredibly at 1700 or 1800 RPM.
Powermaster 20% low viscosity, OS #F plug, APC 18 x 8.
Thanks for help.
3D Joy is offline
Old 06-25-2003, 03:08 PM
Dave Shadel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are priming it the right way.
I think you have too much prop for the 20% fuel. Either go to 30% heli fuel or down to an 18x6.
A header tank won't hurt, but why go to the extra hassle?
Dave Shadel is offline
Old 06-25-2003, 05:37 PM
rcprecision
rcprecision's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DZ Priming
Be careful turning the engine over for that length of time that may flood the engine. My experience has been with both DZs I am running is if the engine has not run for several days I open the throttle to full and the needle 3 turns from the running position turn with the electric starter for only 2-3 seconds reset needle attach the glo driver and engine should start. If the engine was recently run follow the same steps except I leave the needle at the running position when priming.
Radio South makes a glo driver that indicates when engine is flooded and increases voltage to the plug to burn off excess fuel.
rcprecision is online now
Old 06-25-2003, 05:59 PM
3D Joy
3D Joy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about my exhaust setup ?? Is that correct to run that long a tube (7") as an exhaust system.
3D Joy is offline
Old 06-25-2003, 06:53 PM
Dave Shadel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The exhaust should be OK as long as the tubing diamater isn't too small.
Glen- Thanks for the heads up on this.
Good Luck at the NATS!
